- 01-07-2013, 04:44 PM
Thread Author #1
Help with weather widget
I just switched from iPhone to a new Samsung Galaxy S3. Very frustrated, but working through some of my issues with this new platform. One of the most frustrating problems I can't figure out is this: I bought this phone from ATT but NOT in the town I live in. So, this weather widget that comes pre-loaded (which I like, BTW) defaults to a town which I only visit several times a year. How can I get it to default to where I live????
- 01-07-2013, 06:20 PM #2
Re: Help with weather widget
I don't have that widget since JB update.. Not sure why.
But I'd try actually clicking the widget (like your going to open an app) and look around in there. Since you're coming from iPhone the best thing I can teach you is always look in settings. Unlike iPhones each Android app and widget can have their own settings which are set within the app.. Whereas iPhone they consolidate it all under "settings".
So open the widget and hit your menu button (bottom left of phone) and see what options there are.
Sent from my Sprint S3 using AC forums - 01-07-2013, 08:10 PM #3
If there aren't any settings for the widget in the app itself, try deleting the widget from the screen, and then re-adding it. Most widgets bring up a configuration menu when first installed.
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 01-08-2013, 07:49 AM #4
One of the stock weather widgets had a setting for My Location and then any town you added. By default I think mine was set to the town. I changed it to My Location and it "followed" me thereafter.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.
AOKP 4.2.2 Milestone 1 - 01-08-2013, 08:11 AM #5
You can enable your location in the phone's settings and then tap on the widget and it should show you the weather for wherever you are. You can also add a location by pressing the menu button inside the weather widget and going in the settings and putting in your zip code for wherever you want your default location to be. You should be good after that
My GS3 sleeps in the bed and I make my girlfriend sleep on the couch
Help with calendar widget
By indiane in forum Google Nexus 7 TabletReplies: 2Last Post: 08-07-2012, 07:28 PM -
For everyone who has issues with weather widget
By Jude526 in forum Verizon Droid IncredibleReplies: 12Last Post: 02-19-2011, 11:41 AM -
Need Help with Beautiful Widgets for Fascinate
By bigxrich in forum Verizon FascinateReplies: 2Last Post: 10-29-2010, 02:03 PM -
help with weather and toggle app
By tmax1964 in forum Android ApplicationsReplies: 0Last Post: 08-06-2010, 09:46 PM -
Help with uninstalling widget
By Darthbull in forum Motorola Droid Rooting, ROMs and HacksReplies: 10Last Post: 02-19-2010, 05:08 PM
Reply
