Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By gwappa
  • 1 Post By meyerweb
    Default Battery Notification
    Is there like an app wherein if your battery is already 100% while charging? The phone will make a notifying sound so the phone will be prevented from over charging.
    Thanks!
    Sent from my GT-I9300 using Android Central Forums
  2. #2
    Default Re: Battery Notification
    It is not possible to over charge the battery in the S3, or any modern phone. I leave my phone on charge overnight. Once the battery is fully charged, the phone stops charging the battery.
    Thanked by 2:
    mhinc likes this.
  3. #3
    funkylogik's Avatar
    Posts
    ROM
    touchejiz
    as above but "battery notifier" app gives a lovely big coloured percentage in status bar and tells you when youre full or getting low
    funnily enough, when the phone thinks its full, "BN" notifies you bout 10min later.....
    it also tells u temperature and voltage in notification pull down if u want
    the big "15" is battery notifier and changes colour from green as the power goes down
    oh plus it makes a smiley face when its full and u can choose the tone
    Unbranded international rooted s3 with Official 4.1.2 JB. Paisley, Scotland, Western Europe :beer:
    GT-I9300, UK
    Quote Originally Posted by gwappa View Post
    Is that so? :o Thank you for that useful information.
    Quote Originally Posted by funkylogik View Post
    Since my phone doesn't get overcharged then I guess I won't be needing this. Thanks for the app though.
  5. #5
    crester's Avatar
    Posts
    Global Posts
    361 Global Posts
    The phone itself will give you a message when the battery is full... but as others have said... you don't have to worry about overcharging... it just stops charging when it's full.
  6. #6
    LightFlow will let you set the threshold when you want to be notified the battery is charged. For example, you could set it to start blinking the green light when the battery is at 90%.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    crester likes this.
