1. migue897's Avatar
    Well I have this problem I don't know since when but I think it's since y got internet on my phone but I'm starting to get worried because when I start charging my device charge extremely slow and sometimes dosent charge just show the signal like is charging My Samsung galaxy s3 screen drainy battery-uploadfromtaptalk1357931008848.jpg
    And the battery gets extremely hot and I know that is not normal I think the screen spouse to drain like 15% or something but no 84%!!! Please answer asap
    Sent from my GT-I9300 using Android Central Forums
    01-11-2013 01:05 PM
  2. Almeuit's Avatar
    Well I have this problem I don't know since when but I think it's since y got internet on my phone but I'm starting to get worried because when I start charging my device charge extremely slow and sometimes dosent charge just show the signal like is charging Click image for larger version.
    It sounds like your charger cord may be giving out since you are sometimes plugged in and it's not charging. Try another charge + cord to see if it yields the same result.
    Also are you just having your screen left on? Mine auto turns off after a minute of no use. The screen usage should be high on the battery consumption when you use your phone since the screen is always the biggest drain... But the reason it is 84% is because your monitor is showing no other apps taking up usage. (see mine below for an example). So what are you doing during this charge?
    Also as for the heat.. Mine gets hot. Never noticed anything bad from it.. It's just when you use the network it gets hot.
    Sent from my Sprint S3 using AC forums
    Attached Thumbnails My Samsung galaxy s3 screen drainy battery-uploadfromtaptalk1357932952166.jpg
    01-11-2013 01:35 PM
  3. ttwiitch's Avatar
    Op is your phone flashed to another company??
    Sent from my Galaxy S3
    01-11-2013 01:46 PM
  4. migue897's Avatar
    Thanks I'm going to try to change the charger cord and how i reduce my screen
    Usage because i have to auto turn off 1 minute
    01-11-2013 03:13 PM
  1. My Samsung Galaxy S3 voice announces my calls and texts.
    By exl500 in forum General Help and How To
    Last Post: 08-18-2015, 01:12 AM
  2. How to Tether my ipod touch w/ my samsung galaxy s3
    By smileysb in forum Samsung Galaxy S3
    Last Post: 01-03-2013, 10:22 AM
  3. Samsung Galaxy s3 smashed screen, battery bent, won't turn on
    By Daniel Wu in forum Samsung Galaxy S3
    Last Post: 01-02-2013, 08:40 AM
  4. My clock on my samsung Galaxy s3 won't work...
    By tiffanyranae67 in forum Introductions
    Last Post: 10-18-2012, 03:14 PM
  5. Kies will not connect to my Samsung Galaxy S3 ( SCH-I535 )
    By gblaca in forum Verizon Galaxy S III
    Last Post: 10-05-2012, 09:25 PM
