1. Wnrgway's Avatar
    I've always heard that switching to WIFI is recommended to use less power when compared to 4G. I've been experiencing the opposite. When at work on 4G I have significantly less battery draw.
    I'm currently rooted and running CleanRom 5.6, but the same thing was happening before rooting. I would assume that when connected on Wifi that mobile data isn't connected, even if the toggle is turned on and vice versa when connected to mobile data. Under the advanced Wifi options I have "Keep Wifi On During Sleep" set to Never.
    Any ideas?
    01-17-2013 11:55 AM
  2. les017's Avatar
    Is it possible that you have several background-intensive apps set to NOT background sync when on mobile?
    01-17-2013 11:59 AM
  3. Almeuit's Avatar
    Good idea Les. This could be a possible issue.
    Sent from my Sprint S3 using AC forums
    01-17-2013 01:10 PM
  4. Wnrgway's Avatar
    Thanks...I'll have to go in and check.
    [edit] It looks like Google Drive and Currents were both set to sync in wifi only. I've made adjustments for those. Now I just need to see if it makes any difference.
    01-17-2013 02:20 PM
  1. Android OS battery usage is higher than screen usage?
    By briansmithphotography in forum AT&T Galaxy S III
    Last Post: 08-17-2012, 02:29 PM
  2. Battery Life on the Epic 4G
    By qwertyasdfasdf in forum Sprint Epic 4G
    Last Post: 06-08-2011, 07:50 AM
  3. Really weird battery usage on 4G vs 3G today
    By rcpa in forum Verizon HTC Thunderbolt
    Last Post: 06-02-2011, 08:10 AM
  4. Battery usage on droid x
    By tmax1964 in forum Motorola Droid X
    Last Post: 08-25-2010, 07:55 PM
  5. Less battery usage under Wifi
    By thenameisgabe in forum AT&T Captivate
    Last Post: 07-25-2010, 11:26 PM
