Rockbeast
I have read that about 5 mm is the maximum distance between induction coils. Assuming 2mm for the casings (1mm for each, the device back and the mat/qi charger), 3mm remains...hopefully many cases will work. My Otterbox Defender is probably a bit much...but I can find a 2mm thick case I like. My experience with the touchstone (I have the Palm Touchstone equipped back for my S3) is that more than 1.5mm prevents charging. When I take my otterbox defender outer 'gel' cover off, the inner hard plastic case adds about 1 to 1.5 mm to the back, and sometimes I can get the charging to work.
I asked over at Energizer about what distance there can be between the charging mat and the device back. Here is the reply the Energizer Bunny gave me...at least I HOPE it was the Energizer Bunny...I trust him...or her. Besides, he/she thought I had a GREAT question...that made me feel special!
A nickel...Jeffersonian or Buffalo? So, buddy can you spare a dime would be fine. But don't "go to double nickel when you hit the ridge..." anybody know the rest of that line or what song it's from? But I digress. I'm hopeful I'll be able to have a good case and wireless charging in the future. But you sure can't beat the deal you can get on those Palm touchstones right now!
Did you see they said great question? I'm so proud.
Thank you for this great question, I would be happy to assist you. The distance between the pad and the receiver is a critical factor. If the protective case is less than the thickness of a nickel, there is a good chance the charger will work. If the protective case holds the receiver more than a nickel width from the pad, the charger will probably not work.
