EC TECHNOLOGY 2300mAh Li-ion Battery review
EDIT: The review and testing of this battery has ended. It did provide a little extra juice. For $10 it was great. I will not be checking this thread again.
Had this battery for about a week now. So far so good, seems like I'm getting more use out of it. It doesnt seem to heat up as much as the original one.
[Only registered and activated users can see links. Click Here To Register...]
Here are some pictures.
with overnight
Re: EC TECHNOLOGY 2300mAh Li-ion Battery review
I'm amazed u got only 21‰ on screen time
Anyway, arms l seems like a good battery
whats wrong with that?
So far every night I have about 20-30% left after a full day of use. I also compared this with the battery that came with the phone by using it for a few days. The result is that the original battery has about 10% or less of charge left by the end of the day So far, this has been a very good battery.
Consistent results
It's only 200mAh more than the stock OEM battery! There are large 4300 mAh batteries available for this phone. If I was going to buy a new battery... I would get one of those.
Then you all have a brick instead of a phone, not many of us want that.
with kind of heavy use. i had pandora playing for few hours, a bunch of texting, some youtube and camera usage.
No sh1t, really? Thanx for the obvious.
The whole point is to not increase the thickness of the phone. This battery is the same size as the original one.
