Results 1 to 2 of 2
    Default my Galaxy s3 will not connect to Mac
    Hi i have an AT&T galaxy s3 SGH1747 on android 4.1 and I was going to buy iSyncer so I could have iTunes playlists on my phone. I got the lite version to test it out. My phone cannot connect. It charges but as a camera or a media device with usb debugging enabled or disabled it does not work. I have android file transfer on my mac, but it keeps telling me restart or reconnect device. Kies also cannot detect my device and it used to. My Mac is on 10.7.5. Can someone figure out a way to connect my device?
  2. #2
    Dog5000's Avatar
    Posts
    Global Posts
    366 Global Posts
    Default Re: my Galaxy s3 will not connect to Mac
    Quote Originally Posted by Matt Adamski View Post
    To give you a glimmer of hope. Kies works for me, and perhaps ironically, is the only app that reliably does so for USB connections to my S3. I have OS X 10.8.2 and Kies 2.0.0.12123_7.
    I've tried iSyncr and like it, but as you may have seen there are some interoperability issues if Kies is installed. May also be the case if Android File Transfer is installed along with Kies. There could be some issues over who gets control of the USB subsystem when the phone is plugged in. I have had zero success with AFT, but for others it appears to work great. Winamp has a beta synch utility for iTunes as well. Its on my list to check out further as I'm considering using the Poweramp player again. The links below are some good resources to pour through. Hope this helps.
    http://forums.androidcentral.com/ver...ml#post2394873
    http://forums.androidcentral.com/sam...ml#post2375634
    Kies for Mac and Mountain Lion not working? Here's a solution [From the Forums] | Android Central
  1. ...Contacts input directly to my Galaxy S3 do not Sync with Gmail
    By Ethan417 in forum General Help and How To
    Last Post: 12-25-2012, 08:19 PM
  2. Kies will not connect to my Samsung Galaxy S3 ( SCH-I535 )
    By gblaca in forum Verizon Galaxy S3
    Last Post: 10-05-2012, 09:25 PM
  3. Replies: 4
    Last Post: 09-28-2012, 04:25 PM
  4. Will not connect to android file transfer on Mac
    By manbearpig073 in forum US Cellular Galaxy S3
    Last Post: 09-02-2012, 06:39 PM
  5. My Inspire will not connect to home Wi-Fi network
    By bduran727 in forum AT&T Inspire 4G
    Last Post: 02-29-2012, 10:52 PM
