Re: Samsung Galaxy S3 wifi connection problems since firmware upgrade
reset does not work, reset my gs3 twice , also *#0011# does not work. or shut down restart , no. been told its 4.1.2 update prob, the phone used to have auto, 2.4ghz and 5ghz choice but this has been removed from phone. not totally savvy bout this , but seems very plausable, will have to wait for 4.2.2. hope it will sort it
just an addittion to my earlier post, i was at afriends house who has orange livebox wifi. my phone connected via wifi straight away and kept a stable connection.
on arriving back home i tried to connect to my virin media super hub, surprise surprise it didnt connect. obtaing ip address , disconnecting, low signal when i have strong.
seems like the phone doesnt like virgin
hi all , i contacted o2 and told them about my wifi problem, the guy kept blaming my virgin super hub, he would listen till i told him my partners and daughters phones (sg3`s ) and computers all connect without a fuss.i see he said. so he said my phones mac address settings could be wrong and not compatible with virgin. he then asked me if i had registered my wifi i said i dont think so and didnt understand. he said send a text ( wifi to 2121) i had a message back saying thankyou for your wifi reset request, you will be able to register your device using this mobile phone number in approx 1 hour.
with half hour i looked at my phone and bloody hell my phone was connected to my wifi , this was at 9pm 1st june it is now 6.42 2nd june and the phones wifi is still strong and stable
