V J
@Samtheman7, if I'm not mistaken, "Android System" is usually the lump sum of all your background processes running behind the scenes (or most of them). Things like sync services, mail exchanges and widgets. Do you have anything like those that are maybe continuously retrieving data or syncing in the background. The worst culprits would be weather widgets that are constantly using GPS to determine your current location and retrieve weather information on the go. You can check what sort of processes you have in the background by doing this:
1. Long-press the home button and click on the pie chart icon.
2 Click the "RAM" tab and press "Clear memory".
3 Press the "back" capacitive button back to your homescreen again and long press the home button again.
4. Press the trash bin icon this time, then the back button and wait a few seconds. Now only your default processes should be running, as in the ones set to start-up when your phone boots up, and ones that are set to start back up when killed.
5. From your homescreen go into Settings > Applications manager > swipe left to "Running" and you will see a list of background services active. Have a look and see if you can see any that may be causing the battery drain, if not take screenshots of the list.
@meyerweb Apple - Batteries - iPhone
"Use iPhone Regularly
For proper maintenance of a lithium-based battery, it?s important to keep the electrons in it moving occasionally. Be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down)."
That's the only one I could find with a quick google search but I've read a few other similar notes from different sources. It's not a widely advertised practice but it's definitely advised if you're suffering from inconsistent battery life. If your battery performs to expectations though I wouldn't worry about trying to recalibrate it using this method. Honestly though, I've never had batteries fail on me because I tend to upgrade my phone at least once every year or 2. But my partner's phone battery lasted roughly 4-5 years before an abrupt failure, it wasn't a gradual loss of charge capacity and that remains my only experience of battery failure.
But like I said, the minimal impact on the battery's operational lifetime is inconsequential since most of the time you'd have upgraded your device before the battery starts showing signs of failure. But if you're absolutely set on using your device for years to come, and you have no issues with the battery performance, then you don't have to bother with discharge cycles. Otherwise, fully discharging it and letting the battery calibrate is an easier option than having to replace it.
