Results 1 to 4 of 4
    Exclamation Galaxy S3 keeps connecting to XBOX 360 semi-randomly
    So for some odd reason this has happened various times now, Galaxy S3 seems to sometimes connect to the XBOX 360 randomly.
    Sometimes when on the Galaxy S3 viewing pictures, the phone seems to connect to the XBOX 360 and boots off anybody using it in the house. And what ever pictures the galaxy is displaying appear on the XBOX 360.
    Is there any way to stop this?? Bluetooth on the Galaxy is off, so no idea how it keeps connecting. It has happened a few times, any suggestions appreciated!
    Thanks.
  2. #2
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    Default Re: Galaxy S3 keeps connecting to XBOX 360 semi-randomly
    Wireless and networks under settings. Then go to near by sharing. Uncheck file sharing.
    If that's not it i think it has to do with wifi direct. So go to wifi. Then wifi direct. Then click stop.
    Think it's the first solution I mentioned though
  3. #3
    My wife's phone is doing the same thing but all wifi direct, NFC tethering, beam s beam and dlna file shareing is turned off but still some how connects to xbox when viewing pictures without any kind of prompt or ok to do it. Does anyone know how to correct and stop this beside turning off wifi?
  4. #4
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    Check xbox settings. I think you can turn ability for it to connect to devices off.
  1. Galaxy S3 to Xbox 360 DLNA
    By r6yr in forum Samsung Galaxy S3
    Last Post: 05-20-2013, 07:09 PM
  2. Samsung Galaxy s3 Wont connect to my Computer.
    By Nathan Benefield in forum Samsung Galaxy S3
    Last Post: 05-13-2013, 05:42 AM
  3. samsung galaxy s3 not connecting to laptop
    By daud mushtaq in forum Samsung Galaxy S3 I9300
    Last Post: 01-28-2013, 09:05 PM
  4. New Galaxy S3, keeps going to 2g (Edge)
    By anteck7 in forum T-Mobile Galaxy S3
    Last Post: 11-24-2012, 12:06 PM
  5. Galaxy S3 to Xbox 360 DLNA
    By r6yr in forum General Help and How To
    Last Post: 07-26-2012, 08:53 AM
