1. Rich182's Avatar
    My S3 has never had a great battery, but in the last few days it has been terrible.
    It went completely dead (rare for me) on friday night and since then a full charge is dropping about 10% every 30 mins with hardly any use whatsoever.
    Anybody know what the problem might be?
    Been thinking of buying a new battery but thought I would see if there is a fix first.
    Any help appreciated.
    01-28-2013 08:21 AM
  2. V J's Avatar
    There's a recent similar post with a few possible solutions in the replies, it might help.
    http://forums.androidcentral.com/sam...defective.html
    01-28-2013 08:25 AM
  3. Rich182's Avatar
    I have tried disabling things, installed task killer (which helped a bit) but it is still really bad.
    Would a factory reset make a difference? If so, what is the best way to back up apps, texts, etc??
    01-28-2013 08:30 AM
  4. nrm5110's Avatar
    Task killers will hurt more than do any good. Also wake locks are the likely culprit
    Sent from my refrigerator
    01-28-2013 08:40 AM
  5. Rich182's Avatar
    Wake locks?
    01-28-2013 08:46 AM
  6. nrm5110's Avatar
    People are quick to jump the gun blaming hardware or android.
    Wakelocks are caused by apps keeping the phone from going into deep sleep properly causing massive drain even during idle times give me a few I'll give you an example
    01-28-2013 08:50 AM
  7. Rich182's Avatar
    Also just realised, on battery info in settings, it says '22 hours 12 on battery'
    I just took it off charge an hour ago which took it from 15% to 100%. (currently 48%)
    Do we think the battery might be dying?
    01-28-2013 08:51 AM
  8. nrm5110's Avatar
    Look at the battery graph if the lines awake and screen on don't match almost perfectly some things running in the background. This is the most common and most missed cause of battery drain.
    01-28-2013 08:57 AM
  9. nrm5110's Avatar
    Your phone didn't register the phone as being charged to 100%. If it thought it hit 100% the graph would reset and only show discharge from 100%.
    01-28-2013 08:58 AM
  10. Rich182's Avatar
    Yep you're right, awake is pretty much full and the screen on is just dots here and there.
    The graph shows it going up and down rather than resetting. Shows like this for about the last four charges.
    01-28-2013 09:25 AM
  11. Rich182's Avatar
    01-28-2013 09:32 AM
  12. nrm5110's Avatar
    You have absolutely terrible wakelocks. You have rouge apps somewhere.
    01-28-2013 09:55 AM
  13. Rich182's Avatar
    How do I detect which ones?
    01-28-2013 09:58 AM
  14. nrm5110's Avatar
    If you aren't rooted I dunno.
    Otherwise betterbatterystats on the market.
    01-28-2013 10:06 AM
  15. V J's Avatar
    I posted this on the other thread as well, this is how you can find out what services you have running in the background, not just cached apps.
    1. Long-press the home button and click on the pie chart icon.
    2 Click the "RAM" tab and press "Clear memory".
    3 Press the "back" capacitive button back to your homescreen again and long press the home button again.
    4. Press the trash bin icon this time, then the back button and wait a few seconds. Now only your default processes should be running, as in the ones set to start-up when your phone boots up, and ones that are set to start back up when killed.
    5. From your homescreen go into Settings > Applications manager > swipe left to "Running" and you will see a list of background services active. Have a look and see if you can see any that may be causing the battery drain, if not take screenshots of the list.
    01-28-2013 10:33 AM
  1. S3 Battery Drain Problem. What do I do?
    By Ben Hovinga in forum Samsung Galaxy S3
    Last Post: 05-10-2013, 09:08 AM
  2. Galaxy S3 battery problems, normal or not?
    By -xKevin- in forum Samsung Galaxy SIII I9300
    Last Post: 01-06-2013, 10:52 PM
  3. Smemo (battery problem) galaxy s3 19305
    By Mochu in forum General Help and How To
    Last Post: 12-26-2012, 07:41 PM
  4. Having a battery problem with Droid
    By StingrayJG in forum Motorola Droid
    Last Post: 06-08-2010, 08:54 AM
  5. HTC Hero (Seious battery problems)
    By tomwazza in forum HTC Hero
    Last Post: 12-19-2009, 08:29 AM
