Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By GSDer
    Shanicenicolle's Avatar
    Posts
    Global Posts
    1,899 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery suddenly sucks
    I've barely touched the thing! It's weird how much my battery life varies I have days like this and then 20 hours days
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
  2. #2
    crester's Avatar
    Posts
    Global Posts
    648 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery suddenly sucks
    Are you in poor reception areas on those bad days?
    Posts
    Global Posts
    1,899 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by crester View Post
    No today I was actually in the city which has better reception. Turned off Lte to see if that helps for now
  4. #4
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When's the last time that you restarted the phone? Android System is chewing up way more power than it should, so a reboot may help settle things down.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    msndrstood likes this.
    Posts
    Global Posts
    1,899 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GSDer View Post
    It had been a while but I had to pull my battery for the Lte fix so let's hope that helps as well. Thank you!
  6. #6
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not just restart, but power completely off and then restart. My battery life got suddenly worse about a week ago. I figured out what part of Android System was causing the drain, and a restart didn't fix it, but a power down did.
    Posts
    Global Posts
    1,899 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay I'll try thanks again
  1. Trying everything, battery still sucks.
    By adellc3 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-20-2011, 11:43 AM
  2. DL30 battery life sucking?
    Last Post: 02-15-2011, 03:29 PM
  3. Help, my battery life sucks!
    By lolreconlol in forum Verizon Fascinate
    Last Post: 11-02-2010, 10:55 AM
  4. Battery life suddenly sucks! Help please.
    By droidX1991 in forum Verizon Fascinate
    Last Post: 10-19-2010, 12:17 AM
  5. My battery still sucks.
    By jmjccwatson in forum HTC EVO 4G
    Last Post: 07-03-2010, 01:54 PM
