Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By meyerweb
    Angry Screen goes BLANK during call in progress..HELP!!
    Hi Guys,
    My screen goes blank while a call is in progress. I can't end the call even the home, back and menu answell as the power button does nothing to make the screen come back on!
    The only way to get it working again is to take the battery out!
    Th phone and screen works fine any other time apart from when a call is in progress.
    It just happened today, the phone has never been dropped or damaged.
    Please help, this is very annoying.
  2. #2
    Default Re: Screen goes BLANK during call in progress..HELP!!
    Does it go blank when it's near your ear while talking on the phone or at other times? If it goes blank when near you ear that's what the phone is supposed to do. The screen is supposed to come back on after you move the phone away from your ear though.
    I know the phone screen goes black when the phone is held up to the ear, but my problem is that the screen still remanis blank even when i move the phone from my ear or even when i press any buttons....
  4. #4
    I haven't seen this. Have you tried powering down completely, and rebooting? Just like on windows, a reboot fixes many minor ills. Have you recently installed any new software, or changed any configurations related to power saving?
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    bubz786 likes this.
    I have rebooted it and still the problem is there. I haven't changed any settings or installed new software. The only thing i downloadd was the met office app yesterday.
  6. #6
    Quote Originally Posted by bubz786 View Post
    Not sure what the met office app is but if the phone worked correctly before you downloaded that have you tried removing that app to see if the phone works properly?
    Yeh i will try and uninstall it and see if it solves the problem.
  8. #8
    hey,
    did you manage to get the problem sorted? I've just gone to make a call and found I have the same problem, nothing on this post helped so I figured that it didnt help you much! Found another forum that had the answer. The sensor that turns the screen on and off, if develops a fault can cause this to happen. The 'Proximity' sensor can be turned off in call settings and this should solve the problem - it did for me!! (i dropped my phone last night and its put a crack over the sensor!)
  9. #9
    what you only need to do is do a calibration Als_ps' calibration and it would solve your problem....
    GO To Display setting and Calibrate Als_ps' calibration
    before calibrating place your finger on Sensors and press Calibrate...
    It worked for me
    mail me if it worked for you also
  10. #10
    I don't have any calibration options under display settings. What version of the OS are you using? I'm on 4.1.2. Do you have an S3?
  11. #11
    Insp_Gadget's Avatar
    Inspector Gadget
    Posts
    Global Posts
    2,050 Global Posts
    ROM
    "Jellybean" 4.2.2 Stock
    The OP seems to be long gone, but I'm betting that this is a case of having a poorly-executed screen protector applied. Those are notorious for interfering with the proximity sensor on phones.
    I've even seen cases where a person didn't remove the clear plastic shipping film on the phone, which of course interfered with the sensor.
    --Inspector Gadget
    Palm OS:Palm V / Palm IIIc / Visor Prism / Visor Phone / Treo 270 / Treo 600 / Treo 650
    Windows Mobile: Treo 700wx / HTC Touch Diamond
    WebOS: Palm Pre
    Android: HTC EVO 4G / HTC EVO 3D / Motorola Xoom / My Daily Drivers: Nexus 7 / Nexus 10 / Galaxy Nexus
  1. Screen goes black during call
    By gathome in forum Droid Bionic
    Last Post: 11-08-2012, 06:20 AM
  2. Replies: 15
    Last Post: 01-11-2012, 02:15 PM
  3. Screen goes black during calls
    By weihl165 in forum HTC Droid Eris
    Last Post: 12-23-2011, 08:21 PM
  4. After Gingerbread update screen goes blank on call.
    By bassman in forum Motorola Droid 2
    Last Post: 10-27-2011, 08:00 PM
  5. Phone screen goes black during call
    By zack822 in forum LG Optimus S
    Last Post: 04-21-2011, 06:47 PM
