Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Vet69
    Default NFC and S Beam Issue
    [FONT=Times New Roman][/FONT I have just purchased another S3 for my wife and tried to to a file/data transfer from my google play music list to her phone. I turned on the NFC and S Beam, put both phones together and then tapped my screen to transfer the music files to her google play music, but no transfer took place. Can someone give me some guidance as to why this is not working properly? Any advice is appreciated and I thank you in advance!
  2. #2
    Default Re: NFC and S Beam Issue
    That music on ur Google play is it in tha cloud or on ur mc
    Sent from my SGH-T999 using Android Central Forums
    The music is on my 32GB mini SD card. Thanks for helping out if you can!
  4. #4
    You have to do it from within the Play music app. Open the Play Music app, open the playlist or song from the app, then touch phones with the app still running
    smooth, thanks for your post. I tried that, including individual songs and it still didin't work. I had WiFi Direct on, Android Beam on, NFC on, and S Beam on. I could touch the phone and it vibrated, but didn't xfer the music in the google play list app. Any other suggestions?
    Rashawn29 likes this.
  6. #6
    Tkbredx's Avatar
    Posts
    Global Posts
    1,839 Global Posts
    ROM
    TeamSonicFreeGS3 v9.1
    Quote Originally Posted by Vet69 View Post
    After touching phones and feeling the vibrate did you touch the screen?
    You bump, feel vibrate, touch screen once (it should tell you to do so) after touching it look at the screen see if it says in progress or whatever it says when you send things.
  7. #7
    Does ur wife have it on too? It has to be on for both phones... Does it work with a picture? Try it with a photo from Gallery and see if it works.... Also make sure she has the music app on her phone
    Sent from my Samsung Galaxy S3 Boyyyyyy!
    - LOVING MY GALAXY S4 EXYNOS BEST I EVER HAD! -
  8. Thread Author  Thread Author    #8
    smooth, thanks for your help! My wife and I both have the Galaxy S3 and have the same apps. I opened my Gallery and her Gallery and successfully transferred pics. But when I have Google Play Music app opened on both phones, I tap the screen on my phone, feel it vibrate, but nothing further happens. It doesn't give a "transferring files" message. Guess I'll have to take it back to Verizon to see if they can help me. Thanks again for our help!
    Aaaahhh! Problem solved! I stopped by my friendly provider today and the person told me that I was trying to S Beam from the Google Play Music which is an app. He showed me how to go into Music Player, which comes hard loaded with the Galaxy, select one song and when it starts playing, hit the pause. Then you can pair the phones and transfer one song at a time. Could be a lengthy process since I have over 230 songs in my collection, but my will be able to pick the songs that she wants from my collection, then download whatever ones that she wants. Smooth, thanks for your advice, you were right, we just weren't in the same place to do the transfer. Take care, Vet69.
  10. #10
    Seems like an extremely lenghty process to do this one-by-one. Wouldn't it be easier to simply connect each via USB to a PC/Laptop and transfer music files over?
  1. NFC Beam Issues
    By ApologeticKid in forum Google Nexus 7 Tablet
    Last Post: 01-12-2013, 08:01 PM
  2. ROM Update in the works...Battery issues and low signal issues addressed
    By jnick#ac in forum Verizon Droid Incredible
    Last Post: 06-23-2010, 03:26 AM
  3. Anyone using a stock SD card and NOT having issues?
    By showmrock in forum HTC EVO 4G
    Last Post: 05-29-2010, 01:19 PM
  4. Gmail and Contacts Sync Issues.
    By Kaizmuth in forum Motorola Droid
    Last Post: 03-07-2010, 05:03 AM
  5. handcent sms and stock sms issue
    By BostonDroid in forum Motorola Droid
    Last Post: 11-21-2009, 02:02 PM
