Results 1 to 15 of 15
- 02-04-2013, 11:57 PM
Thread Author #1
s3 NOT CHARGING WHEN PHONE IS TURNED OFF!!! HELP PLEASE???!!!
Hi, I'm new to this site. But, I looked everywhere and I couldn't find an answer to my issue.
Here is is my issue:
I have the Galaxy S3... and when I turn off my phone fully I know it charges super quickly. Obviously, because it is not being in use. Anyways, today I was trying to charge my phone whilst it being turned off and it wouldn't charge. I know it wasn't charging because the red light usually comes on at the top and plus you see the charge battery sign on the screen. However, it wasn't charging and it kept vibrating/buzzing. I tried a different charger..wouldn't work. I took out the battery and put it back in and it wouldn't work. I just tried plugging the USB wire into my laptop and charging it through my laptop and still vibrating/buzzing after a few seconds. Agh, can anyone help me or explain to me what's wrong!??
. It's not even a year old and I love it. My bro told me to factory reset it and I do not want to do that. HELP PLEASE!!
Abia - 02-05-2013, 10:09 PM #2
Re: s3 NOT CHARGING WHEN PHONE IS TURNED OFF!!! HELP PLEASE???!!!
Do you have another cable you can try? Charging problems usually seem to be an issue with the charger or cable. Did you use the same cable with the second charger and computer USB port?
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 02-06-2013, 08:03 AM #3
Also how long did you take the battery out for? Try removing it for 30 seconds to make sure it's completely off. Kind of sounds like it's not completely turning off or is stuck in a boot loop.
Sent from my SCH-I535 using Android Central Forums - 02-06-2013, 10:07 PM
Thread Author #4
- 02-06-2013, 10:09 PM
Thread Author #5
- 02-06-2013, 10:32 PM #6
Does it start buzzing/vibrating as soon as you put the battery in, or only once you turn it on?
Does it buzz/vibrate continuously, or in some pattern?
Is anything shown on the screen?
If you can even get into the Recovery mode, your best bet would be to do a Factory Reset. If you can't even get into Recovery then it's time to take it in to a store. Sorry, that's all I can think of.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 02-07-2013, 01:24 PM
Thread Author #7
- 02-09-2013, 10:38 PM #8
On one hand, I'm really glad I've found somebody else that has this same issue. On the other, I didn't see a resolution
. Just the reinforce the OP -- I have the same circumstances. Charging battery icon used to appear when the phone was turned off and plugged into the charger. Now it just vibrates for about a second every two to three seconds and never stops. Nothing is displayed on the screen and it appears it is not actually charging. It does, however, charge properly when the phone is booted. Now a little background on what may have lead to this issue. I originally rooted the phone via the Odin stock image w/root injected. It worked this way for several months, surviving the upgrade to JB with no issues. I was even able to sync it with kies after disabling USB debugging and a lot of cursing. I had been "clean" from my ROM addiction since I purchased the handset last August-ish but relapsed last week. I tried installing CWM recovery using a terminal emulator command. Upon reboot, I was stuck in a boot loop that kept displaying the blue "Recovery Booting...." in the top left corner of the screen. I don't know for sure what happened but the handset was encrypted at the time and I'm thinking this may have contributed. I was able to recover from the boot loop by booting into download mode and selecting the reboot option. From here I was able to boot the system successfully and unwisely continued to decrypt the phone and flash CWM via Rom Manager which was successful. I say unwisely because I probably should have thoroughly checked for proper function of the device before flashing further. It was at this point that I tried connecting my handset to PC to transfer music files with no luck. At first I thought I had contracted the dreaded USB driver issues. I spent the next three days troubleshooting the driver issue. I tried everything (and i really mean everything) with no luck. Not even Odin recognized my device. It was then that I discovered the powered off charging issue. It is possible but not probable that the USB/charging issue started before trying to flash the CWM recovery since I hadn't tried connecting the handset to my PC for about three weeks prior. The battery not charging while turned off also leads me to believe it's a handset issue and not a driver issue. I have since tried flashing a new recovery and ROM in hopes that this would fix the issue. No luck. Please somebody for the love of god help me with this and please understand that when I say I've tried all the USB troubleshooting steps that I really have. I do not believe this is where the problem lies. Many thanks in advance for any help.
More info:
Galaxy S3 (SGH-T999)
TWRP Recovery v2.4.1.0
Infamous 4.3 ROM
Win7 64bit PC (no kies currently installed) - 03-04-2013, 11:08 PM #9
- 03-05-2013, 04:49 PM #10
I've had the same problem for a few weeks now and so far the only way I can get my phone to charge is through the USB port on my T.V. It also only charges while it's turned off. Today I took it apart and tried to clean the charging port on my phone since all last night it didn't charge. It seems to be charging now.
- 03-08-2013, 09:23 AM #11
- 03-08-2013, 12:21 PM #12PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-27-2013, 01:32 AM #13
I noticed the same problem lately. My phone was not charging very well overnight when plugged into the Samsung charger. However I had noticed that if I plugged it into the USB port of my laptop then the charge rate was excellent.
I did some self diagnostic test (swapped cables etc.) and discovered that it charges from the power and the laptop very well if I used my old Blackberry USB cable... Ironic huh!?? @Samsung - A bit more quality control please!?? - 05-07-2013, 03:56 PM #14
Hey Friend i had this issue actually it is caused by Root you have to unroot the phone then check it ... It will charge when turn off .. I dunno whats wrong is happening but you have to be unroot ...Just check it and message me If it works beacause my phone was not charging also i unroot it and now its charging...
- 05-08-2013, 10:45 AM #15
Sorry, but rooting doesn't cause this. There are a great many of us on this forum using rooted S3s having no charging problems.
Battery does not Charge While Phone is Off (One X+)
By BuddhistGirafe in forum HTC One XReplies: 2Last Post: 01-24-2013, 09:51 AM -
Outlook calendar appt will not appear on phone when reminder is turned off
By amccombs in forum Samsung ContinuumReplies: 0Last Post: 06-09-2011, 01:19 PM -
Do alarms work when phone is powered off?
By goin_nil in forum Verizon Droid IncredibleReplies: 10Last Post: 07-15-2010, 02:25 PM -
Does the EVO charge when it is turned off and plugged in?
By Schmid7y in forum HTC EVO 4GReplies: 8Last Post: 06-04-2010, 01:42 PM -
Wallpaper changes when phone is turned off
By macjazzy in forum Verizon Droid IncredibleReplies: 3Last Post: 05-07-2010, 04:07 PM
Reply
