Results 1 to 4 of 4
- 02-07-2013, 07:25 AM
Thread Author #1
Battery seems to be draining fast
How does this look
Sent from my SAMSUNG-SGH-I747 - 02-07-2013, 08:14 AM #2
Re: Battery seems to be draining fast
The 4g lte using most of the batt based on the 2 signal bars. What is your brightness set at?
Have you tried turning of blue tooth, gps, wifi if not using it and 4g lte? And see if that helps.
Forgot to add, how are you using the phone?
I am sure somebody that knows a lot more about this phone will post with more optionsCurrent phone-att galaxy S3 red.running panroidKANGdroid.
Blackberry curve-> iphone 3gs->iphone 4s->galaxy S3 - 02-07-2013, 09:11 AM
Thread Author #3
Everything is off bluetooth wifi gps. I was messing around with widgets and texting that's it. Brightness is on manual and turned way down
Sent from my SAMSUNG-SGH-I747 - 02-07-2013, 03:54 PM #4
Well, you've had the screen on for over an hour, and lost about 30% of battery. My experience has been that I can generally get between 3 and 4 hours of screen on time before my battery is dead, so I don't see anything wrong with your stats.
I usually keep the screen brightness at minimum unless I'm in lighting conditions that require it to be brighter, and I turn it back down when I'm done.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
My battery seems to be going downhill lately
By msoprano13 in forum Sprint Galaxy S3Replies: 3Last Post: 10-05-2012, 06:29 PM -
My Evo $G battery seems to be dead. Won't charge or turn on. White screen blinks...
By storino03 in forum HTC EVO 4GReplies: 5Last Post: 01-01-2011, 01:52 PM -
BetterCut no longer seems to be working...
By kaivorb in forum HTC EVO 4GReplies: 7Last Post: 08-16-2010, 12:09 PM -
Evo seems to be programed not to respond when laid down.
By estebancam in forum HTC EVO 4GReplies: 18Last Post: 06-07-2010, 02:45 PM -
Coming from Pre!!! seems to be a few of us!
By cswee10582#ac in forum webOSReplies: 6Last Post: 10-19-2009, 02:51 PM
Reply
