DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 8 of 8
    Default Red led on constantly
    I'm having a problem with my led indicator. it stays on constantly when the screen is on or off. it is a bright red color. I do not have anything installed like light flow to influence it. I have all the notification options unchecked and I have tried rebooting. What is wrong with my phone?
  2. #2
    Default Re: Red led on constantly
    Try shutting the phone off, pulling the battery for a minute or two, then restarting.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    I tried that and when I insert the battery even before the phone is turned on the red light starts glowing.
  4. #4
    Typically the red LED comes on when the battery charge drops below a certain level. What is your battery gauge (or percentage, if you have that enabled) showing? If you have the battery fully charged, is it lasting a normal amount of time, or dying very quickly? If the latter, then there's likely something wrong with the battery (although there could be something wrong with the charging circuit in the phone).
    Assuming that you don't have access to another battery, I'd do a Factory Reset just to eliminate any settings that you may have inadvertently changed (or any apps that may be causing the problem). If that doesn't fix the problem then it's time to take it in or call Customer Service.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    My phone has lost battery faster and my charger doesn't charge it quite as fast. Is there a way to cancel or shut off the led?
  6. #6
    Ricky Babalu's Avatar
    BEACH BUM
    Posts
    ROM
    Stock : Rooted, Unlocked
    Quote Originally Posted by samsunggreg View Post
    My suggestion would be to rule out the battery. Take it in to the carrier where you purchased and have them try a different battery.
  7. #7
    mine also like that, same like you i try everything included hard reset but still not working, now my phone stay red whenever the phone is switch on or off, do you find the solution ?
  8. #8
    One idea: download the free version of Light Flow, check "enable clear all" in the General Settings, install the widget, and press the red circle with the white dot in the widget. This is a "reset all notifications" button. You can uninstall the app if you don't want to keep it.
    Notes:
    I have the paid version, but I think the free version includes the widget.
    I don't know if it will work, but it will only cost a few minutes to try.
    Be sure to follow all the setup instructions. It takes more than just downloading to get this app working.
  1. What is the front LED on the top right for?
    By mizmellyjelly in forum AT&T Inspire 4G
    Last Post: 04-10-2011, 04:11 PM
  2. Handcent LED on DPro
    By NickB2005 in forum Motorola Droid Pro
    Last Post: 12-15-2010, 01:58 PM
  3. New red LED notification
    By lsmunoz in forum Motorola Droid X
    Last Post: 11-04-2010, 02:00 PM
  4. the red thing on the camera came off.... :(
    By cusco in forum Verizon Droid Incredible
    Last Post: 08-29-2010, 03:59 PM
  5. Pink/Red Tint on New DI
    By rugbyua9 in forum Verizon Droid Incredible
    Last Post: 06-04-2010, 05:18 PM
