Results 1 to 1 of 1
- 02-11-2013, 03:09 AM
Thread Author #1
[q] 4.2 sd card swap script?
I cannot seem to get this kind of script to even read anything from ROMs I run. I have tried it on Rootbox and Pacman, both 4.2.1 based.. I update busy box, and check intd support, but it shows both as my 16GB, and root explorer only shows the external SD card for all storages paths..
In my block/vold/ I have both 179:97 and 179:96
Now the storages are as such
Mnt/storage/emulated/legacy
Mnt/storage/emulated/0
Mnt/storage/sdcard0
These are all internal
Mnt/storage/sdcard1
This is external
Mnt/storage/usbdisk
I have no idea
And the typical
Mnt/extSdCard
Mnt/sdcard
Is there a script that works with possible 4.2.1 JB? Anyway you could help me please? Thank you so much!
Sent from my DeathSCYTHE..
I'll see you in hell.. where the devil knows my name...
SD card swap question
By LoveMyPhone in forum Sprint Galaxy S II Epic 4G TouchReplies: 3Last Post: 09-17-2011, 11:30 PM -
SD card swap? apps? data? what?
By st in forum HTC EVO 3DReplies: 2Last Post: 06-24-2011, 03:21 PM -
Can you Hot Swap SD Card
By rinnr1 in forum Motorola Droid XReplies: 6Last Post: 06-27-2010, 12:20 AM -
Will swapping out micro sd cards screw things up?
By MannyZ28 in forum HTC EVO 4GReplies: 2Last Post: 06-05-2010, 01:25 PM -
"Damaged SD card" after battery swap
By cm40 in forum Verizon Droid IncredibleReplies: 7Last Post: 05-09-2010, 10:12 AM
Reply
