Results 1 to 21 of 21
Like Tree4Likes
  • 1 Post By Edgraham75
  • 1 Post By ryanr509
  • 1 Post By deanodrums
  • 1 Post By meyerweb
    Default Screen uses up 40-50% battery
    Hey guys,
    I'm on a rooted S3 and according to my battery chart, my screen uses up 50% of my battery usage. Is there anything I can do besides using the phone less?
    Currently using Baked blackbean Mod 7 ROM if it makes a difference. Ive always had this issue, even when I was stock. Maybe I like the phone too much!
    Thanks!
    Sent from my SCH-I535 using Android Central Forums
    Sent from my S3
  2. #2
    Default Re: Screen uses up 40-50% battery
    Screens are the #1 killers of battery's.... No MOD is ever gonna change that...lol
    Nexus 4
    Nexus 10
    Thanked by:
    crester likes this.
  3. #3
    About the only things u can do to help is turn down brightness and screen timeout
    crester likes this.
  4. #4
    Stop looking at it.
    Set your timeout to as short as you can handle.
    Turn your brightness down as low as you can and still see what you need.
    Blessed are they who can laugh at themselves, for they shall never cease to be amused.
    AOKP 4.2.2 Milestone 1
  5. #5
    Quote Originally Posted by Edgraham75 View Post
    Quote Originally Posted by trucky View Post
    Stop looking at it.
    These. The screen is usually always the #1 cause for battery drain
    Sent from my Sprint S3 using AC forums.
  6. #6
    Or just have it as bright as you want and just have a spare charger with you? Just a suggestion
    unlmtdRW likes this.
  7. #7
    V J
    V J is offline
    V J's Avatar
    Posts
    Global Posts
    85 Global Posts
    No it's totally normal. Everything else just consumes minimal battery in comparison to the screen. I'd only be worried if something is coming close to using as much power as the screen because nothing else should be. It doesn't mean your battery won't last as long though.
  8. #8
    The screen is supposed to be the #1 user of battery power, it's the only thing that's constantly on when you're using your phone. Nothing is wrong with your phone.
  9. #9
    It's normal.
    Just get an external charger and sparr battery from eBay so you can charge one while you use another battery. They make them for all of the best phones on the market.
    sent from the best smart phone (not phablet) on the worst network- the Galaxy S3 unfortunately on T-Mobile
  10. Thread Author  Thread Author    #10
    Darn, haha. I was hoping for something to help. I have to use it less :sly:
    Sent from my S3
  11. #11
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    nolittdroid likes this.
  12. #12
    Oh also you're going to see people on here claiming to get 2 days worth of battery - understand that these people BARELY Use the phone.
    . There isn't a phone out that can last 2 days unless you barely use it
  13. #13
    Quote Originally Posted by The Hustleman View Post
    I'd have to agree.. When I use my phone (including its data) it can drain. Wifi helps but.. Not too much. I can usually get my days worth though. I use it mostly at work (streaming music and browsing forums / news) and as you can see I am at half. I can last on this until I go home and then to bed tonight.
    Attached Thumbnails Attached Thumbnails Screen uses up 40-50% battery-uploadfromtaptalk1360619284412.jpg   Screen uses up 40-50% battery-uploadfromtaptalk1360619294489.jpg
  14. #14
    Can't edit the post above (getting some error) but forgot to post screen time.
    Attached Thumbnails Attached Thumbnails Screen uses up 40-50% battery-uploadfromtaptalk1360619908391.jpg
  15. #15
    V J
    V J is offline
    V J's Avatar
    Posts
    Global Posts
    85 Global Posts
    That's true to some extent. I've noticed that my partner's iphone 5 lasts twice as long on standby on a single charge, my S3 can make it 2 days with minimal usage, his can get up to 4 days. By minimal usage I don't mean pure idle. On moderate-heavy usage they're about on par.
    Attached Thumbnails Attached Thumbnails Screen uses up 40-50% battery-screenshot_2013-02-05-14-23-48.png
  16. #16
    DroidXcon's Avatar
    Posts
    Global Posts
    11,734 Global Posts
    ROM
    Stock for now
    Quote Originally Posted by nolittdroid View Post
    there is an app called privacy filter in the market it will let you turn down the brightness even lower.
    Also just incase you were not aware (because some people are not)
    the percentages are not reflecting the usage of the battery rather the percentage of what has been used.
    So if you have 70% left on your battery then you have used 30%. So when the screen displays 50% usage it is basing that number off the 30% that was used, so 50% of 30% is 15%.
    If i've made life easier buy me a Macchiato
  17. #17
    Quote Originally Posted by V J View Post
    Not bad if that's you moderate to heavy usage. Last night before charging i snapped a photo of mine.. I was on 3g most of the day so if I had wifi for longer periods of time the battery would have easily lasted longer. (I'm on wifi in the photo due to getting home)
    Attached Thumbnails Attached Thumbnails Screen uses up 40-50% battery-uploadfromtaptalk1360676801030.jpg   Screen uses up 40-50% battery-uploadfromtaptalk1360676932549.jpg   Screen uses up 40-50% battery-uploadfromtaptalk1360677020148.jpg
  18. #18
    Just knowing that percentage really doesn't tell anything in relation to battery life. You need to look at time that the screen is on.
    Also remember that everything using the battery has to add up to 100 somehow.
  19. #19
    V J
    V J is offline
    V J's Avatar
    Posts
    Global Posts
    85 Global Posts
    Quote Originally Posted by Almeuit View Post
    Nah that was actually about moderate to light usage. I leave my brightness on 100% (automatic) and during heavy usage like non-stop watching movies and gaming I'd only get upto 8 hours with the screen using up over 70% of battery power. But still very impressive. One time during a long *** drive I put on a full movie in the car, no car charger, just a full length 2.5 hour movie playing non stop and I only lost roughly 20% battery from a full charge. Was also using GPS on the way to and from the destination, that's when I knew I picked the right phone.
  20. #20
    it's not a percentage of battery, it's a percentage of battery usage relative to everything else. big difference and no cause for concerns.
  21. #21
    mhinc's Avatar
    Posts
    Global Posts
    448 Global Posts
    Something I didn't see others mention as well, use a Black Background, no fancy pics or live wall papers, that will help as well
    Samsung Galaxy S3 SGH-I747M JB 4.1.1
    LG Nexus 4 JB 4.2.1
  1. Screen taking up 73% of battery???
    By NeoX12 in forum Google / Samsung Galaxy Nexus
    Last Post: 12-10-2012, 12:53 AM
  2. Screen using ~80% of my battery
    By nlombardi3 in forum Verizon HTC Thunderbolt
    Last Post: 04-20-2011, 11:34 AM
  3. Data sync uses up your battery.
    By droidntn in forum Motorola Droid X
    Last Post: 10-10-2010, 09:22 AM
  4. Replies: 28
    Last Post: 07-23-2010, 09:36 AM
  5. Battery too low for to use Flash at 50%??
    By AldousSnow in forum HTC EVO 4G
    Last Post: 06-15-2010, 09:48 PM
