Results 1 to 9 of 9
    Default Problem with music playing through device speakers even when headphones are plugged in.
    Has anyone else experienced this problem? Sometimes (not every time) When I am playing music through either my headphones or a aux cable in my car, If I switch over to a different app or to text messaging, the music will stop playing through the headphones and start playing through the device speakers. Is this a software bug with JellyBean, or is it a problem with the phone? Thank you
  2. #2
    Default Re: Problem with music playing through device speakers even when headphones are plugged in.
    I am also a getting this should I get a replacement?
  3. #3
    Before you jump the gun, you should be a little more specific about your problem.
    1. What music app are you using?
    2. Is this a problem with the stock headphones?
    3. What are you doing when the problem occurs - switching to a different app; switching to the Home screen; etc
    A little information will go a long way towards someone being able to help you.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  4. #4
    I'm using the stock Android music app
    This also happens with Pandora and songza
    The problem occurs when you listen to music via headsets then launch an app that uses any sort of audio such as temple run 2 or fun run the music audio starts playing through the speakers instead of the plugged in headset
    I tried 5 different ear buds already
  5. #5
    Does it with mine also. I consider it to be a bug.
    Samsung Galaxy S3 4gLTE
  6. #6
    Default
    Quote Originally Posted by AxlMyk View Post
    I don't consider it a bug as 2 of my 4 friends with galaxy s3s
    The same verizon one. And 2 of them don't have it all of them are completely stock
    I'm going to get a replacement on Monday I'll let you know how it goes
  7. #7
    I'm having the same problem. I think it is a bug in the new software I updated to a couple days ago. Been having the problem ever since.
  8. #8
    Default
    Quote Originally Posted by Grant Wilson1 View Post
    What software was that jelly bean?
  9. #9
    Smile Re: Problem with music playing through device speakers even when headphones are plugged in.
    I just got my s3 march 8th and iam having this problem as well,but it happens when im doing nothing at all when Iisten to the standard mp3 player. the screan is locked most of the time.in my pocket or laying flat.I thought I was my music files but I had another phone b4 this and I never had that problem. I was thinking it was the device and I should replace it but I see.its not just me.have you found a solution yet?
  1. Problems with music app force closing
    By roberttyson in forum Motorola Xoom
    Last Post: 02-25-2011, 11:18 AM
  2. What if I have a problem with my insurances replacement device?
    By kingneptune117 in forum Motorola Droid X
    Last Post: 10-31-2010, 07:00 PM
  3. Problem with music
    By drake22 in forum Sprint Epic 4G
    Last Post: 10-21-2010, 10:31 AM
  4. Froyo Problems With Music?
    By rustler753 in forum Motorola Droid X
    Last Post: 10-13-2010, 09:34 AM
  5. problems with music player after update
    By highbloodsugar in forum Verizon Droid Incredible
    Last Post: 09-30-2010, 10:51 AM
