Samsung Galaxy S III need help w/ APN settings for switching to Straight Talk
GrooverMomma
4
I have a G S III that was originally w/ t-mobile but the customer service help said I need to use the settings if it had been with AT&T???? That doesn't make sense to of the APN settings they gave me have worked. My husband has a GS II and in places where he has full coverage I have none w/ my GS III. Also my internet is extremely SLOW and I can not send or recieve pictures either. Can someone PLEASE give me the correct APN settings and any tips to speed up my internet ? THANK YOU SO MUCH IN ADVANCE!:cool:
Thanks for your response. I have tried several. All settings I have taken from the threads on here but there always seems to be some "glitch" that remains. I 'll try that one though. :) Do you know what actually makes the coverage better? I just don't understand why my husband has an S II & I have an sIII both with staright talk byo phone plan but side by side I have no bars & he has full coverage.
This is what I put on my sgs3 and my wifes. Everything works and its fast.
APN: att.mvno
Proxy: <not set>
Port: <not set>
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS Port: 80
APN Type: default,supl,mms,hipri
Thank you SO MUCH. I'll try it. Did you leave everything else blank? What do you have for the following?
So far I have:
APN: mvno
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: Not Set
MMS port: 80
MCC: 310
MNC: 410
Authentication type: not set
APN type: default,supl,mms,hipri (with NO SPACES right?)
APN protocol: IPv4
Enable/disable APN: (this is set to APN enabled) it's in gray and can not be changed
Bearer: Unspecified
THANKS AGAIN FOR TAKING THE TIME & ALL YOUR HELP
Here are the settings I use on my T-Mo One S on Straight Talk:
APN: wap.tracfone
Proxy: Not set
Port: 8080
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mms.tracfone.com
MMS proxy: Not set
MMS protocol: WAP 2.0
MCC: 310
MNC: 260
Authentication type: Not set
APN protocol: IPv4
In addition I have an MMS APN set up:
Name: Straight Talk MMS
MMS proxy: 216.155.165.40
MMS port: 8080
MCC: 310
MNC: 260
APN type: mms
APN protocol: IPv4
Hope this helps.
@ wickedcontra. THANK YOU, THANK YOU, THANK YOU!!!!!!!!! My gf was really upset, as she should have been that her phone wasn't working. A brand new unlocked GS3 from Best Buy. The settings that straight talk provided worked for about a month, and then just stopped. I've been fighting with this for almost a month now. Again, thanks.
So what's hipri for and will it work with/add anything to my ST T-mo settings?
Sent from my HTC One S using Android Central Forums
@wickedcontra
THANK YOU!!!! Got my phone to work with these settings as well...tried another from youtube...it didn't work. SOOOO happy!!! :)
my galaxy s3 from t-mobile doesnt work even after i do all the setting changes. do you one for that??
@Blaize19.....ur settings work gr8t. They are the same that is sent w/instructions on how to setup the SIM card.
I did input those settings but since I didnt read the manual 4 the S3 I assumed it auto saved upon exiting. some of the settings I inputed wasnt there DUH!!!
So all day 2day I couldnt do nething but call and basic txt. No S Voice, no pic txting, no internet, no navigation, ONLY NETWORK errors.
I love GOOGLE......................it found this site.
Love my S3 to and I'm a newbie to it
Re: Samsung Galaxy S3 need help w/ APN settings for switching to Straight Talk
Hey i have all those settings in my straighttalk samsung galaxy s3. it was an att phone but i cannot get the original att settings to delete so it will work off of the straighttalk settings. any idea how to do that?
you can't delete them as far as I know. Just create a new APN and make sure you save it. Then switch to it.
Im glad it has work for some of you. im still with straight talk using the same settings using sgs3. make sure there are no spaces in the last row.
This is what I use on my Galaxy s3 Straight Talk At&t sim
Name
Straight Talk ATT
APN
att.mvno
Proxy
not set
Port
not set
username
not set
Password
not set
Server
not set
MMSC
MMS proxy
66.209.11.33
MMS Port
80
MCC
310
MNC
410
Authentication type
PAP or CHAP
APN type
APN prtocol
IPv4
APN roaming protocol
IPv4
APN enable/disable this should be lighter and already checked.you shouldn't be able to alter it
Bearer
unspecified
using these settings I am getting 5.5 dn and 1.25 up
