1. Andy Robinson's Avatar
    my samsung s3 wont allow some apps work properly ...angry birds is one that the advert pop up restarts the app so it never gets to start playing ...others are one like words with friends that plays but wont connect to Facebook ..another is candy crush ..the act of trying to connect restarts the app
    I have reinstated each of these apps and Facebook and regularly reboot my phone and always try when on wifi and mobile data .....help ?
    02-15-2013 04:18 AM
  2. mattatwar1's Avatar
    well for one the Facebook app is complete junk
    02-15-2013 04:41 AM
  3. meyerweb#CB's Avatar
    I don't have Candy Crush, but I have no problem with WWF or Angry Birds, or the Facebook app. What sorts of mods have you made to your phone? I suspect something you've added or changed is interfering. Are you using any kind of battery saver, task manager, or ad blocking software? Have you disabled any apps?
    02-15-2013 07:59 AM
  4. Andy Robinson's Avatar
    I do have an anti virus and an app killer .I'll try it with them disabled cheers
    02-16-2013 12:33 PM
  5. meyerweb#CB's Avatar
    My bet would be on the app killer. They really aren't needed on recent versions of Android, and often cause more problems than they're supposed to solve.
    02-16-2013 02:46 PM
  6. Robert Armijo's Avatar
    I'm having issues with my Samsung Note. I can't login to ANY of my apps through Facebook....
    06-13-2013 05:32 PM
  7. Sarah Caldwell1's Avatar
    Same problem with myTouch Q. Not a single app will connect with my facebook. the page I keep getting when I try is "Web page not available" "View cached copy at google". So frustrating that I completely reset my whole phone..... To no avail.
    07-12-2013 06:21 PM
  8. budhapriest's Avatar
    05-03-2017 05:15 PM
  9. budhapriest's Avatar
    I don't have Candy Crush, but I had problem login using facebook with Madden Mobile and Fifa 17
    I had to disable ad blocking on rooted android s7edge (xposed module) after that it worked just fine. thanks
    05-03-2017 05:15 PM
  10. budhapriest's Avatar
    05-03-2017 05:16 PM
  1. Replies: 7
    Last Post: 09-24-2014, 02:06 PM
  2. Problem with apps not launching from the SD Card
    By rg3000 in forum AT&T Inspire 4G
    Last Post: 05-05-2011, 12:52 PM
  3. facebook problems with apps
    By isabel.conde89 in forum HTC Desire
    Last Post: 04-22-2011, 12:04 PM
  4. Digg app not connecting
    By tjubb in forum Android Apps
    Last Post: 08-29-2010, 04:20 PM
  5. problem with apps and display?...help
    By Kamran1981 in forum Motorola Droid
    Last Post: 01-17-2010, 05:17 PM
