1. richard10002's Avatar
    UK S3, 9300?
    When using personal hotspot, I keep getting a pop up telling me that switching to WiFi will turn personal hotspot off. I have the option to cancel or agree to switch to WiFi. If I do nothing, personal hotspot continues to work, and the popup remains...... So not a big deal but I am wondering if something is searching for WiFi, even if wifi is off? If so, it must be using battery?
    How can I tell if something is searching for a wifi connection, even if I have WiFi turned off?
    And how can I stop the popup, which is more irritating than anything else?
    I'm guessing solving the first question will resolve the second
    Many Thanks
    Richard
    02-17-2013 06:59 AM
  2. dustini1948's Avatar
    I have exactly the same condition, unfortunately with no answer. I look forward to the resolution.
    02-19-2013 06:23 PM
  3. richard10002's Avatar
    Looks like its not a common problem, so not much yearning for a solution. I can live with it - it doesn't seem to affect how the phone works.
    02-27-2013 03:02 AM
  4. meyerweb#CB's Avatar
    I would think that some other app on your phone is trying to use WiFi. Does the i9300 have anything similar to Sprint's Connection Optimizer, which turns on WiFi periodically to check for available WiFi Access Points?
    02-27-2013 08:16 AM
  5. toddydogood's Avatar
    I have the same issue, the pop-up keeps coming back about every 5 seconds after I say I want to keep the hotspot open. I normally only use the hotspot at work (the work network blocks YouTube and FaceBook, so I use the hotspot to connect my laptop), and I never use the work WiFi with my phone.
    Anyone find a way to turn the pop-up off?
    03-14-2013 08:32 AM
  6. meyerweb#CB's Avatar
    Settings / Wi-Fi / Menu (button)/ Advanced
    Make sure Network Notification is unchecked, and Check for Internet Service is unchecked.
    03-15-2013 11:49 AM
  7. richard10002's Avatar
    Both unchecked when I had a look, so not that?
    03-17-2013 04:28 PM
  8. meyerweb#CB's Avatar
    Are you on Sprint? If so, make sure Sprint Connection Optimizer is turned off. If not on Sprint, and you have some similar capability, make sure that's off.
    Otherwise, do you have any applications installed that might try to do something with network data? I know there are apps that will search for open wifi connections, for example. Anything like that could cause the problem you describe.
    03-17-2013 05:12 PM
  1. Should I keep it or switch to a D2?:(
    By taygo in forum Verizon HTC Thunderbolt
    Last Post: 04-06-2012, 01:35 PM
  2. What would it take for you to switch to Dual Core
    By dougstrickland in forum General News & Discussion
    Last Post: 12-06-2010, 05:35 PM
  3. which carrier & phone to switch to?
    By agraceffa in forum General Help and How To
    Last Post: 11-15-2010, 10:07 AM
  4. Replies: 4
    Last Post: 09-13-2010, 01:51 PM
  5. How current and disappointed users are going to switch to the EVO?
    By jamesedward318 in forum Verizon Droid Incredible
    Last Post: 05-06-2010, 09:08 AM
