1. richv77's Avatar
    My friend just purchased an AC charger for his T-Mobile Galaxy S2 and the sale person said it would charge quicker than a normal charger.
    I tried it yesterday and it was very quick. When I plugged in my S3 it was at 35% and I can swear in was up to 45% in about 10 minutes.
    Are these high speed chargers good for your battery?
    Thanks for your comments.
    -Rich
    02-18-2013 03:02 PM
  2. meyerweb#CB's Avatar
    Well, there's one member here who claims to have tested the S3 and found it won't charge at a rate of greater than 800mA no matter what charger you plug it in to.
    Let's do some calculations: The stock battery in an s3 is 2100 mA. So 35% would leave you at about 735 mA. 45% gives you about 945. That's a gain of 210 mA in 10 minutes, which implies a charge rate of about 1260 mA. So you might want to double check your measurements more carefully.
    But assuming your measurement is correct, I think that as long as the battery doesn't really heat up while charging, you're probably OK.
    02-18-2013 07:05 PM
  1. How long does it take to port # from T-mobile to Sprint?
    By JohnnyBeGood in forum HTC EVO 4G
    Last Post: 06-04-2010, 03:31 PM
  2. Coming from T-Mobile, does Sprint also offer...
    By HoldFastHope in forum HTC EVO 4G
    Last Post: 06-01-2010, 06:13 PM
  3. Replies: 3
    Last Post: 05-19-2010, 05:37 PM
  4. Quick Question - Swithing from BB to Android
    By hawkfrost in forum Motorola Droid
    Last Post: 05-06-2010, 10:33 AM
  5. How to transfer your SMS from your Mobile to PC
    By markyo2009 in forum General Help and How To
    Last Post: 11-24-2009, 09:26 PM
