Hi All,
I was wondering if anybody can help me.
I currently own a Samsung Galaxy S3 on Orange network (In the UK), with jelly bean version 4.1.2 loaded on it. Whenever I try to connect to my home network, which is with Virgin Media it can connect onto the router but not on to the internet. The setting on the router are okay as the 2 laptops and another Samsung Galaxy S3 are connecting to the router without a problem.
I've restarted the router a number of times and had no luck. I did a full factory reset and install on my phone and nothing. I rest all settings and re-configured the setting on my router and nothing. I also turned the power save option off on the wifi settings via (*#0011#), and my phone has been reset a number of times and nothing. I did check for any viruses and the phone is clean.
I had tested my phone on a number of other wireless networks at work and on a couple of home networks (including another Virgin Media connection, with the same router) and connected to the network and internet without a problem. Is there anybody that can help or other ideas on what I can do to resolve this problem/matter.
Thanks on your time and help.
TKNY85
TKNY85
