Results 1 to 9 of 9
    SET001's Avatar
    Posts
    Global Posts
    39 Global Posts
    Default Phone going into Car Mode when plugged in to charger.
    I have an AT&T S3 that is running version 4.1.1. In the last week it has developed a new issue. When I plug it into my charger at home it will automatically go into Car Mode. If I shut down the car mode it will restart after 2 seconds. When in Car Mode it will also automatically start S-voice. It only does this on the charger that I use at home. I have a charger on my desk at work and it has never done it there. The charger at home is the same one that I have used every day since getting this phone and does charge the phone even though it is having this issue. It is not OEM , it’s Blackberry OEM from previous phone, but has worked flawlessly for several months, until this week. Any ideas other than the obvious get new OEM charger would be appreciated. I can do that, but have trouble believing that it worked fine for so long and then just screwed up.
  2. #2
    Default Re: Phone going into Car Mode when plugged in to charger.
    What happens with the original Samsung charger that came with the phone?
    Did your phone receive an update recently?
    Did you install any apps around the time this started? Or have you changed any system settings/power management settings?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  3. #3
    Not sure about this, but check Settings / Accessories, and see if any options are checked.
    I can't find anything that looks like car mode on my S3. How would you activate this intentionally?
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  4. #4
    Did someone hide an nfc tag on your charger?
    Never motivate an id10t because after that you will have a motivated id10t. See troll...
    SET001's Avatar
    Posts
    Global Posts
    39 Global Posts
    Quote Originally Posted by meyerweb View Post
    I can't find anything on my phone in settings either. The only time I see anything is when I plug in I get steering wheel icon in tray and if I go to notifications is says auto mode enabled.
    SET001's Avatar
    Posts
    Global Posts
    39 Global Posts
    Quote Originally Posted by GSDer View Post
    When OEM charger is plugged in it works as designed. The phone has not received any new updates. I may have installed a couple of apps and that is a possible cause but all have been from the Play Store, nothing outside supplied. I have not changed any settings. The strange thing is that even though it happens with a non OEM charger, that charger worked great for several months.
  7. #7
    Just because an app came from the Google Play Store doesn't mean that it didn't modify some profile/setting that's causing this behavior.
    If you know what apps you've installed, you can uninstall them all, restart the phone and then see what happens. Or you could perform a Factory Reset and see if the problem goes away - if it does, then you know that it was an app or setting that was causing the problem.
    Only you can determine if the annoying behavior is worth the effort of trying these things - without more specifics about the 3rd party charger, what apps you've installed, your software version, etc, I don't have any other suggestions.
  8. #8
    Mines the same.. original charger.. but mine messes around even when its not charging.. its really annoying mid - call, car mode on car mode off, so turns loud speaker on and off so fast you cant have a conversation.. actually struggling to write this reply with s voice repeatedly popping up!! my s3 is becoming more hassle than its worth
  9. #9
    To be sure I understand correctly, your phone is switching in/out of Car Mode even when it's not connected to a charger? Did you recently receive an OTA update?
    You could simply disable S Voice and see what happens, or take the big step and perform a Factory Reset. If you do the latter, be sure you backup your SMS/MMS, Call Logs, Pictures/Videos; sync your Google account; if you use an alternate Launcher save your settings; etc.
  1. Phone does not go into USB mode when connecting to Win 7
    By ansextra in forum Samsung Galaxy S3
    Last Post: 12-25-2012, 12:51 PM
  2. Replies: 31
    Last Post: 08-13-2012, 04:26 AM
  3. My 3 wont go into dock mode when docked
    By terrapin in forum Motorola Droid 3
    Last Post: 09-30-2011, 05:11 PM
  4. Phone will charge, then discharge when plugged in
    By shortyjacobs in forum LG Optimus S
    Last Post: 12-14-2010, 10:17 AM
  5. What makes the phone go into dock mode?
    By racermech in forum Motorola Droid
    Last Post: 12-11-2009, 06:30 PM
