Results 1 to 3 of 3
    Default Problem transferring music to my s3
    I supposedly installed the necessary drive for my phone and hooked it up to my pc to transfer my music instead of having it pinned through Google play music. I was getting an error that my phone is missing a section to connect so then my phone had a pop up that said to fix the error download the Samsung kies program ands connect through there attempted that and still no luck I may be a big vague but can anyone help me with this issue
    Sent from my SCH-I535 using Android Central Forums
  2. Thread Author  Thread Author    #2
    Default Re: Problem transferring music to my s3
    Actually it's telling me hard ware id missing
  3. #3
    Dog5000's Avatar
    Posts
    Global Posts
    366 Global Posts
    The pop up message usually occurs the first time you connect your phone via USB to a computer or USB stereo, etc. There's a check box that after selected will prevent the pop up from showing up again. I've not seen the particular hardware ID missing problem before, but from your description sounds like the USB drivers may not have installed fully or correctly. You don't have to use Kies via USB to transfer stuff. Could try Kies Air, AirDroid, or similar WiFi file transfer programs.
    I don't use Google Music though, so not sure if the above will apply in your situation.
  1. Transferring music from my old phone to my new phone
    By peki14 in forum Droid RAZR MAXX
    Last Post: 02-18-2013, 02:32 AM
  2. Problem Transferring Music to Nexus 7 (Problem Solved)
    By ThePacster in forum Google Nexus 7 Tablet
    Last Post: 12-02-2012, 10:38 AM
  3. how do i stream music from my s3 to my tv?
    By Galiete18 in forum Samsung Galaxy S3
    Last Post: 11-22-2012, 10:09 PM
  4. Replies: 1
    Last Post: 03-16-2012, 12:08 PM
  5. Problems playing music in my car...
    By Popocub in forum Motorola Droid
    Last Post: 03-26-2010, 07:12 AM
