Results 1 to 7 of 7
    Exclamation No Operating System on my sprint galaxy s3!?!? Help!!
    Hello,
    when i go into recovery mode on my S3, it goes into Team Win recovery and everything on my device has been clear n erased. But my sd card wasnt plugged in all the way and i wasnt able to backup n save my OS onto the card. so here is my problem, I tried to factory reset and when i go to reboot, it warns me that i have no OS on the devise. someone please help me to get an operating system back onto my devise so i can actually turn it on and use it!!?!?!?!
  2. #2
    Default Re: No Operating System on my sprint galaxy s3!?!? Help!!
    If you can still get into recovery then you should still be able to mount your sd card to your computer. Then from there download a Rom and put it in the root of the sd card then flash it.
    Sent from my LG-LS970 using Android Central Forums
    tried this with many different roms ranging from the original stock rom to custom roms in recovery, it says installing, but one second later it finishes and when i go to reboot it says "no os installed" nothing will install correctly. Even tried to install all these in .tar files thru odin and every single one fails every time. Ever since the first rom failed thru odin i cant even get into recovery anymore.. when i go to get into recovery instead of loading it the phone just says "firmware upgrade encountered an issue. please select recovery mode in kies and try again." Usb debugging was never checked before i lost my os, maybe this has something to do with it? So now that i cant get into recovery and odin always fails how can i install a rom? Even tried to reinstall a recovery thu odin and that fails aswell.
  4. #4
    Your first post says it goes into Team Win Recovery, but the one above says you can't get into recovery. Which is it? What version of the phone do you have? You might want to post in the rooting forum for that particular phone, rather than in the general S3 forum.
    I assume you're booting into download mode, and not recovery, when you try to load a ROM through Odin?
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    it did go into teanwin, but after trying to install .tar files thru odin now it no longer goes into teamwin recovery.. when i try to go to recovery now it just says "firmware upgrade encountered an issue. please select recovery mode in kies and try again." i have no idea what this means or why recovery wont work now.. i have samsung SPH-L710. yes i was booting into download mode when i tried to load a rom thu odin.
  6. #6
    There are some very smart people in the Sprint rooting forum. I'd re-post this there: http://forums.androidcentral.com/spr...ng-roms-hacks/
    Good luck.
  7. #7
    did you ever fix that ?
  1. No FM Radio on AT&T Galaxy S3?
    By Bazinga_ in forum AT&T Galaxy S3
    Last Post: 02-17-2013, 08:16 PM
  2. Spam/Spyware pop up alert on my far Galaxy S3
    By klb86 in forum Samsung Galaxy S3
    Last Post: 11-22-2012, 06:03 AM
  3. I need help restoring the kernel on my sprint Galaxy S3
    By dlx509 in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 10-18-2012, 11:13 AM
  4. Help my Sprint Galaxy S3 is completely DEAD!!! (PLEASE REMOVE)
    By Dulex Cherenfant in forum Samsung Galaxy S3
    Last Post: 09-24-2012, 08:22 AM
  5. can't run flash on my sprint galaxy 4g
    By jan_rifkinson in forum Android Applications
    Last Post: 02-18-2011, 06:44 PM
