Results 1 to 6 of 6
    raino's Avatar
    Posts
    Global Posts
    2,601 Global Posts
    ROM
    Stock 4.1.1
    Default Possible to switch locale permanently?
    I have a Canadian GS3 in the US. Is it possible to permanently switch the locale from Canada to the US without rooting? I have an app, Locale Select, which lets me change the locale, but every time I reboot my phone, it reverts back to Canada. Anyone know of a permanent fix?
  2. #2
    Default Re: Possible to switch locale permanently?
    Guess I'm not sure what Locale you're referring to. Perhaps it's not something that shows up on the Verizon SGSIII. It may be something that's locked to Canada by your carrier?
    Sorry I couldn't be more helpful.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    raino's Avatar
    Posts
    Global Posts
    2,601 Global Posts
    ROM
    Stock 4.1.1
    Quote Originally Posted by GSDer View Post
    Sorry, it's my fault. I should have been clearer in my OP. From : "Locale represents a language/country/variant combination. Locales are used to alter the presentation of information such as numbers or dates to suit the conventions in the region they describe."
    Luckily, since my phone is Canadian (and that too from an English majority region), I don't have major problems with the locale settings. But here are some examples of issues that pop up:
    1. The Yelp app takes me to yelp.ca
    2. Word spellings are different. The Swiftkey suggestions I get are not always for the American English form of the words (oxidised, subsidised, etc.)
    Like I said, not major issues, and (temporarily) resolved by the app I downloaded. I'm however hoping for a more permanent solution.
  4. #4
    Thanks for the explanation - what I was trying to say was that I did not see anywhere in any of the menus on my Verizon SGSIII that allowed you to change any Locale settings. Offhand, the only place I can think of would be in the language settings, but I don't think that's what you're getting at.
    The only place I remember seeing a global Locale setting was right after performing a Factory Reset - I seem to remember a prompt there for something like that. If you're willing to give that a shot you might find what you're looking for.
    If I happen to do a Factory Reset in the next day or so (one is coming up so that I can test out the Lookout remote wipe feature) I'll let you know for sure.
    Thanked by:
    raino
  5. #5
    Well, sorry to say that, at least on my Verizon SGSIII, there wasn't a Locale setting following a Factory Reset. It did prompt me for a default language Possible to switch locale permanently?-uploadfromtaptalk1362474217776.jpg, but that's all there is.
    I did happen to load an AOSP ROM, and that prompted me for a Locale, but I didn't actually change it, so I can't tell you how effective that would be for you.
    Thanked by:
    raino
    raino's Avatar
    Posts
    Global Posts
    2,601 Global Posts
    ROM
    Stock 4.1.1
    Thanks for checking. When I set up my phone, I did get that language prompt screen. However, the "English" option I saw must have been Canadian/British English. Oh well.
  1. Is it possible to switch to the correct way of typing this late in the game?
    By MantisToboggan in forum The Android Central Lounge
    Last Post: 10-11-2012, 09:03 PM
  2. Possible to switch between iPhone 4s & Note?
    By MattMJB0188 in forum AT&T Galaxy Note
    Last Post: 03-27-2012, 12:56 AM
  3. Is it possible to switch SIM cards?
    By zeitgeaust in forum Verizon
    Last Post: 10-12-2010, 10:00 AM
  4. Replies: 1
    Last Post: 09-14-2010, 07:43 PM
  5. Is it possible to switch SIM cards?
    By zeitgeaust in forum Motorola Droid
    Last Post: 02-27-2010, 01:03 PM
