Results 1 to 9 of 9
    Default Case with Samsung 3000mAh battery?
    Which case would fit nicely, must be durable and thin (not the super thin and flimsy silicone cases) with the Samsung galaxy s3 3000mAh extended battery (EB-K1G6UBUGSTD)?
    Thanx
  2. #2
    MC_A_DOT's Avatar
    Posts
    Global Posts
    463 Global Posts
    Default Re: Case with Samsung 3000mAh battery?
    I want to get this battery pack ..hows it performing? sorry off topic
    Quote Originally Posted by MC_A_DOT View Post
    Don't have it yet.
  4. #4
    That's always the difficulty with these extended batteries, even the OEM ones - finding accessories that it'll work with.
    I like the hard plastic holster design that clips on the belt, and it's rare to find one that accommodates the extended battery (although Verizon finally came out with one for my trusty Thunderbolt).
    But it's always something - you find a case, then it doesn't fit in the bedside dock, or your car dock.
    Good luck with that (I just finally got a 10,000 mAH battery pack and use that if I'm somewhere without a charger).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    anyone? my battery got shipped out yesterday, so im going to need a case asap.
    :thumbup:
  7. #7
    Congratulations on your buy. Can you please measure the actual thickness of the battery? I cannot seem to find this information anywhere!
    The original battery is 5mm thick and I want to check if I can fit the new battery inside my UAG case with the back cover removed.
    If they have used the same tech, is should be (roughly) 3000/2100 x 5mm = 7mm. But even a single millimeter counts!
    What mileage are you getting out of it? Has it gone up from let's say a day to 2 days and the intervening night (since we don't really use the phone at night)?
  8. #8
    cpolism's Avatar
    Posts
    Global Posts
    226 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by fripfrop View Post
    I'll add in my 2cents. I got the battery on Thursday. After going through a couple cycles, it has gotten better. I am a very heavy user, so my OEM battery lasted about 8 hours on a normal business day. 14-16 on the weekend when usage is lighter. I'm also in an LTE area. Charged the battery around 2pm yesterday, still going strong today @74%. I'm very pleased so far. And it adds a bit of protection for the camera. The cases that I had do not fit. So I'm using it naked right now. Haven't had much luck finding one.
  9. #9
    msndrstood's Avatar
    Posts
    ROM
    Stock JB 4.2.1
    Check Amazon. I got a Hyperion extended battery 3500 for my Gnex and they had a TPU case that fit it perfectly. I exclusively use TPU cases anyway, so it worked out perfectly for me.
    What?! ...I'm msndrstood.
    via Gnex
    What?!...I'm msndrstood.
    Sent from my Gnex from 'Just Over The Line'.
  1. Nexus case that fits with Samsung extended battery
    By magic4644 in forum Verizon Galaxy Nexus Accessories
    Last Post: 08-09-2012, 02:04 PM
  2. Anyone using a case with the 2000mah Battery?
    By PAC757 in forum Google / Samsung Galaxy Nexus
    Last Post: 05-17-2012, 12:25 PM
  3. Case with built-in battery?
    By flashkillpro in forum Verizon Galaxy Nexus Accessories
    Last Post: 12-21-2011, 09:19 PM
  4. Any cases with the Extended Battery?
    By DzNuttz in forum Incredible 2 Accessories
    Last Post: 10-17-2011, 04:55 PM
  5. Trident Electra series case with integrated extended battery
    By iastonish in forum Thunderbolt Accessories
    Last Post: 05-20-2011, 01:49 PM
