Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By Almeuit
  • 1 Post By Almeuit
  • 1 Post By worwig
    Default Battery Saver 1.5 - A small friendly app saves battery up to 3 days on my Galaxy S3
    Good day!
    I want to introduce my app for battery saving.
    It's very simple, and have no setting.
    With the screen off the program disables WiFi and mobile data, performs periodic synchronization for your facebook,
    twitter, etc...
    App also don't cut off network, if phone uploads photos, or you talking in skype, or phone is charging.
    On my Galaxy S3 it extends life up to 3-4 days.
    Try it for free!
    Some reviews from market:
    brian blanco, 20.02.2013 в 12:14
    Amazing battery saver After just the first day I was blown away with the amount of battery I had left when I went to
    go charge my phone at night. If your looking for a battery saver with real results look no further
    Emanuele Scarponi, 01.03.2013 в 0:30
    Ottima!!!!!! Disinstallato subito juiceDefender....anche perche' e' molto tempo che non viene aggiornato e consuma
    un po' piu ram di questa applicazione,che invece e' ottima,leggera e funziona senza problemi!!!!Ho notato un netto calo
    dei consumi della batteria,dato che riesce e gestire le connessioni veramente bene,ma ha una cosa che le altre non
    hanno,ed e' che quando a schermo bloccato,vuoi premere il tasto home per visualizzare le notifiche o l'ora,lei ti
    attiva il 3g in automatico,coś da scaricare eventuali messaggi dai social network!!!!5 stelle super meritate!!!
    COMPLIMENTI..... e se possibile mettete un'icona sulla barra delle notifiche....grazie!!!!!
  2. #2
    Default Re: Battery Saver 1.5 - A small friendly app saves battery up to 3 days on my Galaxy S3
    I don't mind battery savers but it kills the point of a smartphone when turning off data so my notifications aren't real time.
    Sent from my Sprint S3 using AC forums.
  3. #3
    Quote Originally Posted by Almeuit View Post
    You don't need real time when your sleeping.
    Sent via Tapatalk
    Galaxy S3 w/ Hyperion 4200mah and Seidio battery cover & ZeroLemon 7000mah
  4. #4
    Quote Originally Posted by vietalogy View Post
    Sent via Tapatalk
    Maybe you don't but I do.. I want to wake up to my phone having the notification already.. Not me having to fetch it. Why do you need to save battery when sleeping? Plug in the phone.. Sleep. .
    mahmoud992 likes this.
  5. #5
    I don't mean to criticize the app. I'm sure it does what it says it does. I've just never understood the need to have my charge last for several days, unless I'm going camping or something. Just plug the phone in every night, and use it for what it's designed for. But if saving battery is more important to you than staying connected, then it's nice to have another choice.
    I agree with Almeuit. I want to be notified of important incoming messages and such when they come in, whether the screen is on or not.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
  6. #6
    Quote Originally Posted by ggBatterySaver View Post
    twitter, etc...
    So, when I have my phone asleep in my pocket, and a coworker sends me an email, I don't get it until I turn on the phone?
    No point in having the phone with me then.
    I'll just leave it plugged in at the desk then.
  7. #7
    True, I have a extended battery so no battery saver app for me.
    Sent via Tapatalk
  8. #8
    My phone made it nearly 30 hours on one charger with 24 hours of wifi
    Don't really need an app like this, but will check it out
    I find that most apps like this screw ur your network, by taking it off randomly when in use and other issues, but I'll see what this one is like, hopefully it's not as bad as deep sleep battery saver
    Sent from my Google Nexus 7 running aokp 4.1.2 #AOKP-Till-I-Die
    Android is a tune up sports car with custom interior, sound system, and IOS is a stock model benz
    I use Android, because unlike IOS, i keep my apps in app drawers, and not infinitely cluttered homescreens
  9. #9
    Quote Originally Posted by Soundtrack to Chaos View Post
    Wow, what phone are you using and is that stock battery or aftermarket?
  10. #10
    Quote Originally Posted by Agret View Post
    Aftermarket extended, supposed to be 4200 mah I think
  11. #11
    Spare battery and charger... Best $22 I ever spent!
  12. #12
    Quote Originally Posted by Issemann View Post
    I paid 12 bucks for my battery and it came with a nice tpu case
  13. #13
    Same . Charger at the house and work.. Do those are covered. If i am at a friends or something simply use one of theirs. Bam!
    How is the case? I keep my S3 naked.. I like it more and been going for like 5 months strong.. Still can be scary though haha.
  14. Thread Author  Thread Author    #14
    Muzhi Li, 24.03.2013 в 18:20
    best power saving apps i tried installed it and you dont need to worry abt anything like changing the modes or clean any mess up,
    just use it and you get 50 pc more time of each charge, best $1 you ever spend.
    This version can work with WidgetLocker.
    Config: in phone settings - set screen lock "None", in my app - set "Enable on unlock"
  1. [FREE] [APP] Save battery with OnScreenOff
    By doctorserone in forum Android Applications
    Last Post: 08-28-2012, 04:05 PM
  2. Apps/Widgets to add on my Galaxy Nexus?
    By BigTub in forum Verizon Galaxy Nexus
    Last Post: 12-27-2011, 11:07 AM
  3. Facebook app not living up to Froyo promise...
    By justlaxin13 in forum Android Applications
    Last Post: 02-24-2011, 10:29 PM
  4. apps getting messed up when i turn my phone off
    By uberjam545 in forum LG Optimus S
    Last Post: 02-01-2011, 01:54 PM
  5. Replies: 9
    Last Post: 01-05-2011, 09:55 PM
