Results 1 to 16 of 16
    Question Voice Navigation doesn't work when Blue Tooth is on
    Is it normal that voice guidance doesn't work when Bluetooth is enabled? It doesn't on my Galaxy S3 and I have Voice turned on in the settings menu.
    It took me days to figure out why I could hear sounds for everything but not Navigation when in the car. I hope there is a fix for this because it seems counter productive not to be able to use your phone via Bluetooth and use Navigation for directions.
  2. #2
    Default Re: Voice Navigation doesn't work when Blue Tooth is on
    When my GS3 is connected to my cars' BT, i still get voice nav through the phone speaker or the 3.5" jack. I don't get voice nav through BT.
    Make sure media volume is turned up while you're navigating. That's a different setting than ring or in-call volume.
    PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
    If I've helped you, please press the Thanks button.
    Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
    Thanked by:
    It is turned up as high as it can go. Voice navigation really doesn't work when Bluetooth is on. I will call Samsung the beginning of the week. I'll share whatever I learn.
  4. #4
    Quote Originally Posted by tabletnovice View Post
    Be sure your bluetooth device (not the phone) is A2DP protocol capable. Call the supplier or read the manual if it has a spec sheet.
    A2DP is REQUIRED in order to have navigation or audio OTHER THAN PHONE CALLS to be heard using the device.
    If it's not A2DP compatible, then it's just a "hands free" device, and ONLY PHONE CALLS will have sound piped to it.
    Good Luck & Aloha
  5. #5
    I have the same problem but let me be more specific.
    When I use navigation and my phone is connected to the vehicle through bluetooth there is no instruction from the phone.
    If I disconnect the phone from the bluetooth device then the nav instructions come over the speakers of the vehicle.
    If I uninstall the phone as a paired device then then nav instructions come from the phone.
    Interestingly when I first start the nav app the first instruction comes over the vehicle speakers and then nothing from then on.
    Thre is definitely a conflict between the phone and the app. I have tried google maps and Navigator and the act exactly the same suggesting it is the phone.
  6. #6
    I am unsure of what exactly is causing your issue but i can share my experiences .
    I have a 2012 VW and i use the bluetooth connection everyday and it works perfectly with Google navigation, music and phone. When my phone and media player are paired i can play music with the navigation on and when a verbal direction is given the music volume is reduced and the direction is said and then the music returns to normal. If I recieve a phone call it switches over to the call and when i hang up it goes right back to the music.
    I used to use a cable with my old iPhone and it worked well but since i switched back to Android i have been using bluetooth to connect to my car. When i had my razr maxx i would hear a wierd ticking noise through the speakers when using bluetooth so i started using an aux cable with it to improve the audio quality. Once i purchased the S3 i connected via bluetooth and there was no ticking nose and the audio quality has been excellent so i no longer use the aux cable and i have been very happy ever since.
    My wife on the other hand has a 2012 hyundai and the bluetooth connectivity in her car is poor while on a phone call and intolerable when listening to music so she uses my old aux cable in her car this is both with her razr maxx and my s3. The audio quality is slightly better with my s3 but totally unacceptable to listen to on a regular basis. Not to mention the navigation crackles and delays so you have a hell of a time trying to understand the directions. So it seems that the head unit or transceiver in the vehicle makes as much or more of a difference than the phone. At least from my experience.
    Unfortunately your head unit may be your issue unless you have used other phones successfully in your car. If you have then their is something defective with your phone. If you have not tried other phones with your car that would be a good place to begin troubleshooting. Let us know what you find. Good luck.
    Sent from my SCH-I535 using Tapatalk 2
  7. #7
    I should have added I am using sync by ford which is a Microsoft product
  8. #8
    syncS3 - you don't say what model/year Ford product you have, but if you do some reading you'll come across a bunch of issues with bluetooth and vehicles, and some of those problems are solved by getting the firmware in the car updated (and some of them aren't; or there's no firmware update available - bummer).
    OP - it should work. I have an older car, so I use the Motorola Roadster 2, which is a bluetooth device that you can use directly (you'll hear any audio through its own speaker) or you can use it to broadcast an FM signal and listen to any audio through the car stereo (tuned to the frequency that the Roadster 2 is broadcasting on). In both cases Google Maps navigation audio comes through the selected target just fine. I've even just used a normal bluetooth earpiece before and the navigation audio came through that. Not sure what to tell you - what carrier/software is your SGSIII on? Perhaps a Factory Reset will clear up this mess.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  9. #9
    The phone Galaxy S3 was recently updated to jelly bean the problem was there with the old op system. The vehicle is a 2010 Ford F150. Phone provider is Wind but I don't think this has anything to do with this issue.
    I can say it is obvious the instruction is being routed to Bluetooth but it is not being picked up and therefore no instruction. Even if I could have the phone broadcast the instructions it would be fine but that is not happening. With the phone paired the GPS app automatically tries to broadcast to Bluetooth. I have changed all the audio options but the result is always the same.
  10. #10
    Ha! The dreaded "it was recently updated to Jelly Bean" story.:banghead:
    Actually, since it apparently didn't work correctly when your phone was on ICS, the update obviously doesn't have anything to do with your problem, but just be aware that it's generally a good idea to perform a Factory Reset after a major update like that.
    You should contact Ford to see if there's updated firmware for your vehicle's bluetooth setup. I only know what I've seen from other posts about this topic, but you need to make sure the bluetooth profile for the vehicle is set correctly (if you search for the term MAP, you should find some other posts that are about similar issues).
  11. Thread Author  Thread Author    #11
    Quote Originally Posted by GSDer View Post
    some of those problems are solved by getting the firmware in the car updated (and some of them aren't; or there's no firmware update available - bummer). .
    I have a 2013 Accord. I'll call Samsung, then Honda.
  12. #12
    I had the same problem, i.e., when my Samsung S3 was paired via Bluetooth to my Ford Escape's Sync I could no longer hear Google Maps Navigation voice directions from either the car speakers or the phone speaker.
    If I turned the phone's Bluetooth OFF I was then able to hear the voice directions through my phone's speaker.
    By trial and error I finally fixed the problem. I went to my phone's Settings > Bluetooth and found SYNC as a Paired Device. I tapped on the gear icon to the right of the word SYNC and noticed both the Call audio and Media audio Profiles were checked.
    I unchecked Media audio and now I can still make calls and play my iPod through voice commands using Sync Bluetooth AND I can also hear Navigation voice directions through my phone speakers.
    With this method I cannot stream audio from my phone to my car's speakers but I never did that anyway.
    Thanked by:
  13. #13
    I have a 2013 vw jetta using an LG Optimus9 through t mobile. My Bluetooth works, my audio on a call crackles and the first time I used navigation it said 3 commands through the car speakers since then if I am hooked up to Bluetooth no commands through navigation on either the car speakers or the phone. I since noticed that if hooked up through Bluetooth I no longer get notification sound for email to texts through either car speakers or phone...this stinks.. Anyone have a solution? Is it vw or is it the phone? I am very frustrated!
  14. #14
    Quote Originally Posted by beesee View Post
    This cured the issue for me in my Volvo S60 and my Note 2. Thanks for leading me thru the maze of settings and their affects to cure my issue.
  15. #15
    It's easy...just download the MonoBluetooth Application....then you can hear your music and Navigation through your earpiece/bluetooth. Happy Days!
  16. #16
    Did you ever find solution?
    I have same situation. I got Samsung S4. Pairs fine with Subaru bluetooth for phone calls, but no navigation sound either through car/bluetooth or the phone when bluetooth is on. When I turn the bluetooth off within a couple minutes the navigation voice comes from the phone again.
    (My previous phone a Motorola Droid X would work with the phone sounds coming/going through the car/bluetooth and the navigation sound coming out of the phone speakers.)
    Verizon said the problem is a "known issue" and connected me to Samsung customer service. Samsung rep told me it was issue with Subaru's bluetooth software. I have not contacted Subaru yet. Someone else told me I could get another navigation app that would be compatible with the bluetooth. I also read somewhere that the settings for the navigation could be set to use bluetooth, but I don't see how to change the settings in my navigation app. I'm using what I think is Google (blue arrow). There are thousands of others to choose from...so would another actually work any better?
  1. Touchscreen doesn't work when charging
    By scotchandcigars in forum Sprint Epic 4G
    Last Post: 12-03-2012, 08:17 AM
  2. Voice Command doesn't work / AT&T I777
    By sbi in forum AT&T Galaxy S II
    Last Post: 12-19-2011, 04:08 PM
  3. My internet doesn't work when using voice calls
    By confuzion in forum Virgin Mobile Optimus V
    Last Post: 05-27-2011, 12:48 AM
  4. Voice control doesn't work with bluetooth
    By mikehoff99 in forum Sprint Epic 4G
    Last Post: 12-30-2010, 03:19 PM
  5. "Setting Profiles" doesn't work when phone is asleep?
    By whitenack in forum Android Applications
    Last Post: 08-05-2010, 07:43 AM
