1. Joltcola1234's Avatar
    Talking about the stock battery meter that is built in. Is there an easy way to restart the meter to time each battery charge/discharge cycle? I was assuming that this was how it worked, but mine just seems to continue counting. Example, a charge lasts about 13-14 hours, now the next charge is showing 19-20 hours and counting. It would be nice if the meter restarted at 0 each time.
    edit: I've read that if you let the phone charge fully to 100% before you unplug it the time should restart but this did not happen with my phone.
    03-03-2013 07:33 PM
  2. meyerweb#CB's Avatar
    Charging to 100% resets it for me.
    03-03-2013 08:14 PM
  3. gnr_2's Avatar
    Does using the refresh button work? It should reset at 100%.
    Sent from my totally awesome Sprint Galaxy Nexus, even if I don't know all its secrets yet.
    03-03-2013 08:20 PM
  4. liteon163's Avatar
    I'd wait until the phone tells you to unplug the charger, then unplug it, turn it off, wait a minute or two, plug it back in until it says it's full again, and then reboot. Unplug the phone once it has fully finished its booting sequence.
    If that doesn't work, I don't know what else might...
    Sent from my SCH-I535 using Tapatalk 2
    03-03-2013 09:11 PM
  1. How do you clean the Hero's track ball?
    By infenit101 in forum HTC Hero
    Last Post: 07-13-2011, 07:53 PM
  2. how do you check the battery %
    By basc0 in forum HTC EVO 3D
    Last Post: 07-02-2011, 06:51 PM
  3. how do you reset stock "Youtube" app?
    By camalama in forum Samsung Moment
    Last Post: 04-28-2010, 01:54 AM
  4. how do you exit the standard music player?
    By urban ali in forum HTC Hero
    Last Post: 03-08-2010, 02:46 PM
  5. How do you change the gmail app account?
    By Kamen in forum General Help and How To
    Last Post: 12-31-2009, 02:13 AM
