Freezing Issue
Hi,
I've been reading over previous posts regarding freezing problems on the S3.
Mine has not woke up when I've pressed the home button, froze when apps have started updating, froze while in apps and just randomly restarted itself.
Once I've had to take the battery out and other times I've just held down the power off button.
I haven't loaded any new apps recently. Should I factory reset it or just getin touch with Samsung?
TIA :)
Re: Freezing Issue
The factory reset is a last resort option after you've tried everything else. Give us a list of your most used apps and maybe someone will spot an offender that doesn't play well with others.
Re: Freezing Issue
I'd vote for going straight to a Factory Reset - it'll probably be much quicker than the other alternatives. Your main concern is just backing up your current content so that you can quickly get back to a usable state. Take a look at:
Carbon: [Only registered and activated users can see links. Click Here To Register...]
Kies Air: [Only registered and activated users can see links. Click Here To Register...]
MyBackup Pro: [Only registered and activated users can see links. Click Here To Register...]
SMS Backup & Restore: [Only registered and activated users can see links. Click Here To Register...]
(there are free/trial versions of all of these). Hopefully you already have your contacts, calendar, etc. synced with Google, so you just need to worry about your call logs, SMS/MMS, pictures/videos and the like.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
Re: Freezing Issue
Morning,
trucky - My most used apps are Facebook, Instagram, twitter, Yahoo mail, candy crush. Then gmail, hotmail and ebay.
GSDer - thanks for those, I'll have look.
Edit - it froze this morning when it started automatically updating apps.
Re: Freezing Issue
I've done a factory reset and its frozen about 10 times since...any other advice please?
Plus im not rooted and never have been. Stock TW. Most used apps are google chrome, instagram and carbon/twitter
Re: Freezing Issue
After the factory reset, do you reinstall all your apps? That defeats the purpose of the reset. Reset and leave the phone stock, with no 3rd party apps. As in NO apps, not even Chrome, instagram and Carbon. If it still locks up, it would appear to be an issue that will require a trip to where you bought the phone. If it doesn't, then re-install your apps one or two at a time, run that way for a day or two. Keep track of what you've installed, and see what apps you install just before it starts locking up again.
Re: Freezing Issue
I would try a different launcher. I have heard of TouchWiz causing the phone to freeze. If you wish to try this option, I would suggest Nova Launcher. If you try it and it still fails, you aren't out anything.
Re: Freezing Issue
Update - I disconnected my home wifi from my phone and *touch wood* my phone has been ok. I'm going to leave it disconnected for the moment as I have my mac and ipad at home for internet use :)
