- 03-05-2013, 04:47 AM
Thread Author #1
Freezing Issue
Hi,
I've been reading over previous posts regarding freezing problems on the S3.
Mine has not woke up when I've pressed the home button, froze when apps have started updating, froze while in apps and just randomly restarted itself.
Once I've had to take the battery out and other times I've just held down the power off button.
I haven't loaded any new apps recently. Should I factory reset it or just getin touch with Samsung?
TIA
- 03-05-2013, 06:34 AM #2
Re: Freezing Issue
The factory reset is a last resort option after you've tried everything else. Give us a list of your most used apps and maybe someone will spot an offender that doesn't play well with others.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.
AOKP 4.2.2 Milestone 1 - 03-05-2013, 09:12 AM #3
- 03-06-2013, 01:40 AM
Thread Author #4
- 03-07-2013, 03:15 AM #5
Re: Freezing Issue
I've done a factory reset and its frozen about 10 times since...any other advice please?
Plus im not rooted and never have been. Stock TW. Most used apps are google chrome, instagram and carbon/twitter - 03-07-2013, 08:59 PM #6
Re: Freezing Issue
After the factory reset, do you reinstall all your apps? That defeats the purpose of the reset. Reset and leave the phone stock, with no 3rd party apps. As in NO apps, not even Chrome, instagram and Carbon. If it still locks up, it would appear to be an issue that will require a trip to where you bought the phone. If it doesn't, then re-install your apps one or two at a time, run that way for a day or two. Keep track of what you've installed, and see what apps you install just before it starts locking up again.
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-07-2013, 10:59 PM #7
- 03-11-2013, 06:02 AM
Thread Author #8
EVO 3d Screen freezing issues
By agraceffa in forum HTC EVO 3DReplies: 6Last Post: 02-28-2012, 02:05 PM -
Is anyone else having freezing issues with..?
By jbigdog23 in forum Verizon HTC RezoundReplies: 3Last Post: 01-12-2012, 01:48 AM -
Installed powerwash rom, freezing issues
By mack in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 6Last Post: 08-30-2011, 11:49 AM -
Live Wallpaper freezing issues
By revise in forum Virgin Mobile Optimus VReplies: 4Last Post: 06-06-2011, 10:47 AM -
Did the update for Google search fix your freezing issues w/ Froyo?
By Jerry Hildenbrand in forum Motorola Droid XReplies: 1Last Post: 10-12-2010, 01:32 AM
Reply
