Results 1 to 5 of 5
- 03-05-2013, 09:24 PM
Thread Author #1
- 03-05-2013, 10:36 PM #2
Re: Help me save my data.
You could certainly leave both mobile data & WiFi turned on all the time - as long as you have a good WiFi connection your phone will use that; if you get out of range of the WiFi connection then your phone will automatically switch to using mobile data.
However, to save the maximum amount of your data plan, I'd recommend leaving mobile data turned OFF, and only turn it on when you need something then turn it off again.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 03-05-2013, 11:44 PM #3
- 03-06-2013, 02:00 AM #4
Download onavo from the market and let it do its thing for a few days. It will tell you what apps use all your data
Sent from my SCH-I535 using Tapatalk 2 - 03-06-2013, 04:07 PM #5
Go to Settings / Data Usage and scroll down below the graph. by tapping on each of the apps displayed, and checking the "restrict background data" option, that app will no longer sync data in the background when on a cell connection. It will continue to do background syncing on WiFi. Do this for apps that you don't really need immediate updates for.
PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3
Help me save/root my optimus v
By shssta in forum Optimus V Rooting, ROMs, and HacksReplies: 24Last Post: 10-07-2012, 08:09 PM -
New Replacement Phone On Its Way Help Me Save My Data Please!
By eatsleepdrivesc in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 2Last Post: 06-30-2011, 10:28 AM -
Alright, Android Pro's.. Help me with my new G2
By awoodruff in forum T-Mobile G2Replies: 2Last Post: 10-10-2010, 10:58 PM -
Help me root my MT3G 3.5
By shamefulzero in forum T-Mobile myTouch 3GReplies: 2Last Post: 06-15-2010, 03:28 PM -
Help me with my EVO
By tucci999 in forum HTC EVO 4GReplies: 2Last Post: 06-12-2010, 02:23 PM
Reply
