Results 1 to 22 of 22
- 03-06-2013, 09:23 PM
Thread Author #1
Solar portable charger or portable Battery charger for SGS3?
Hello community,
As the title above, I am kind of stuck between those two choices. Here's the two items I have found on amazon:
Solar portable charger:
Amazon.com: ReVIVE Series Solar ReStore External Battery Pack with Universal USB Charging Port for Portable E-readers , MP3 Players , Smartphones & More USB Powered Devices: Cell Phones & Accessories
Portable battery charger:
Amazon.com: Stay Powered with Yubi Power YP520A 5200mAh External Battery Charger with LED Flash Light: Cell Phones & Accessories
Here's what I think of those two:
Pros:
1. 100% solar powered, don't need external power source.
2. Don't need to worry about limited power charging like portable battery chargers, as they have limited amount of battery.
Cons:
1. Can't use it at night (duh)
2. Slower charging, depending how hot is the sun.
3. Have to put it near the window for sunlight.
Pros:
1. Faster charging than the solar portable charger (I think)
2. Can be put anywhere you want, unlike the solar portable charger you have to put it near the window for sunlight.
3. Smaller than the Solar portable charger, easier to carry around.
Cons:
1. Limited amount of battery, need to recharge it even often.
2. Limited amount of charges allowed on the battery charger before it dies.
So what do you guys think? Both chargers are pretty good price, but I am more to the portable battery charger, due to it's size, and pricing. Any suggestions or comments are appreciated. Thanks.
- 03-06-2013, 09:30 PM #2
Re: Solar portable charger or portable Battery charger for SGS3?
Do you expect to be away from a source of power for days at a time? If so, the solar option is probably best bet. Otherwise, why not spare batteries?
Amazon.com: Boho Tronics ® Set of 2x (two) 2300 mAh Batteries Now With NFC! (Supports Google Wallet) & 1 wall travel USB Charger - Compatible with Galaxy S3 S3 i9300: Cell Phones & AccessoriesPLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-06-2013, 09:37 PM #3
- 03-06-2013, 09:41 PM #4
I can go a week without any power, with 2 spare batteries, a Samsung battery charger/holder and a small keychain sized solar charger. Use a battery up through normal use, put a fresh one in and then stick the depleted battery in the Samsung battery charger/holder and connect the solar charger into it via the micro and mini USB connectors. Takes a bit over a day to charger back up and doing it this way over a week will eventually deplete all the batteries because it is a very small solar charger, but if you absolutely needed to you could conserve and last indefinitely (as long as there is sunlight that is.)
- 03-06-2013, 10:31 PM
Thread Author #5
I totally forgot about spare batteries. That can be a good idea, but, on every single SGS3 battery being sold on Amazon, there is always so much bad reviews, that I am afraid that there will be a chance to buy a defective battery. Still can't decide which one to choose.
- 03-06-2013, 11:09 PM #6
- 03-07-2013, 06:35 AM #7
The portable battery chargers are very handy. They don't take up much space, are relatively cheap, can usually charge your phone battery 2 or 3 times, can also charge USB peripherals like your Bluetooth headset, etc.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.
AOKP 4.2.2 Milestone 1 - 03-07-2013, 07:17 AM #8
- 03-07-2013, 08:50 AM #9
^ What he said
I've got the version prior to this one http://www.amazon.com/gp/aw/d/B0067T...idcentral00-20 (without the flashlight) and have been pretty happy with it.
Of course, I also got the previous version of this http://www.amazon.com/gp/aw/d/B009V5...idcentral00-20 and have been pretty happy with it as well.
If you were going backpacking or something like that, one of these monster batteries + solar charger would be the way to go: leave the solar panel charging the mongo battery at your campsite; come back and juice up the phone.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 03-07-2013, 01:51 PM #10
- 03-07-2013, 08:35 PM #11
I'm using the batteries that I linked to above, and they seem to work fine. Bought the same set for my son, and he's had no problems either. I'll admit a sample size of two isn't statistically meaningful, but the price is low enough the risk seems minimal. And Amazon is really good about returns.
I haven't tried NFC with these, however, so I can't vouch for that.PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-07-2013, 08:43 PM
Thread Author #12
Alright. Think I will be going for portable battery chargers then. Does anyone have good ones to recommend? By the way, why is everyone recommending Anker brand? Is it very reliable? I am new to this, so hope anyone can help me with it.
- 03-07-2013, 08:58 PM
Thread Author #13
- 03-07-2013, 10:08 PM #14PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 03-07-2013, 10:23 PM
Thread Author #15
- 03-08-2013, 04:23 PM #16Samsung Galaxy S3 4gLTE
- 03-08-2013, 08:38 PM #17
You bought an S3. Have you signed up on Samsung's website and registered your phone? Once you do, they send you a 50% off coupon. That means a real Samsung battery for $20. Or 50% off your entire order.
I don't use anker because they lack the NFC chip. Or they did. Haven't bothered to look recently. - 03-09-2013, 05:45 AM #18
- 03-09-2013, 02:16 PM
Thread Author #19
So pretty much I have three choices:
Amazon.com: Anker® Astro 5600mAh Backup External Battery Pack Charger with built-in Flashlight for Apple: iPad mini, iPhone 5 (Lightning Cable not Provided) / iPhone 4S, iPad 2, iPod; Most Android Phones: Samsung Galaxy S3, Galaxy Note 2, all Samsung
Amazon.com: [Upgraded Version] Anker® Astro2 Dual USB Output 8400mAh Backup External Battery Pack Charger with built-in Flashlight for Smart phones, Android phones, PSP, GoPro; iPad mini, iPhone 5 (Lightning Cable not Provided); iPhone 4S; Samsung Ga
The first two are Anker, and the third one is some other brand. The third one is cheaper than the Anker ones. Which one should I go for? - 03-10-2013, 12:20 AM #20
Out of the three that you listed, I'd go with the Anker the 8400 mAH choice.
Let us know how your selection works out.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2 - 03-10-2013, 10:30 AM #21
How much power do you need?
The 5200/5600mahr units should give about two full charges. The 8400 should give you over three full charges. That is why I get the 10,000mahr Anker. I get about 5 charges from it.
If you just need one or two charges, go with the cheaper one. - 03-10-2013, 05:25 PM
Thread Author #22
The Anker 5600 mAh one seems to be a little rip off comparing to the Yubi Power 5200 mAh, so I will choose between the Yubi Power 5200 mAh or the Anker 8400 mAh. I think the 10000 mAh version of the Anker is too big for me. I can't really accept the size of anything bigger than my SGS3.
Portable spare battery charger
By rlmesq in forum Bionic AccessoriesReplies: 1Last Post: 09-24-2011, 11:14 PM -
Portable Backup Battery Chargers
By LadyDi in forum myTouch 4G AccessoriesReplies: 8Last Post: 06-16-2011, 03:11 PM -
By LadyDi in forum HTC myTouch 4GReplies: 1Last Post: 02-14-2011, 08:39 PM -
How to get a: White or Red Battery Cover for your Incredible
By BetaRoc in forum Incredible AccessoriesReplies: 40Last Post: 01-26-2011, 11:41 PM -
By BetaRoc in forum Verizon Droid IncredibleReplies: 9Last Post: 09-05-2010, 10:56 AM
Reply
