Random rebooting? Please help!
Hello, for some reason my s3 will reboot while I'm using it. It happens randomly, usually a few days apart. It just started a week ago. I've narrowed it down to ram usage, but I don't know what is using up all this ram. Its only happening after I upgraded to jelly bean. Anybody else having this problem? I've un-installed some recently installed apps hoping it was one of them that was causing the problem. Any suggestions? Thanks in advance!
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Re: Random rebooting? Please help!
Remove all apps and return them one by one until you find the culprit.
I finally found the problem, it was a samsung push service update I did. Thanks!
