Car mode problem
Kyle Clinton1
Hey there, Thank you all for the suggestions.
I pulled the battery out and cleaned usb port with a toothpick, but being there was debris on the thinner side (the port and wall of the charging slot) A can of air blew my problems away.
Car mode started activating just after I dropped it down my stairs.
This worked for my I9100 (SII), -Rooted with Custom Rom-
Thank you soo much:-$:-$
Afrah_F7
hey there .. i install app called .. Disable car home .. it's rlly work .. i was like u .. care mode driveing me crazy but now its gone .. try it
Lukash Katman
No need to worry about apps' activities. I just flashed a stock rom and and started to get same problem. Car mod on and off! As suggested above, I cleaned USB port with toothbrush and it is working properly now. If you still having same problem, just clean your USB port.
Abdul Kashem
I cleaned my USB port with the toothbrush and guess what its worked! not having that annoying car mode crap.
thanks for the member who recommended use of toothbrush
Davidw2415
My S3 is doing the same car mode thing. It started with the last update on July 4 weekend. Also when it goes into car mode I can't turn the phone off without it turning right back on by itself. Seems to do it mostly when battery power drop below 70%. Also since last update the phone doesn't seems to not recognize the charger when plugged in; I have to remove battery and put it back in then it will be okay until power drops again.
Batzaya
3
Hi guys. I had this problem just. And i readed yr advices. I can clean my usb port. Do u have a any instruction? Video or picture? I rly need help pls guys?
Batzaya
3
hi guys i just had this problem and i readed yr advices. I cant clean my usb port. Can u show how can i do it? Do u have a video picture or someting? Pls!!! I rly need help.
Paul Elgie Tanquis
I have the same problem car mode enable pop up and its very irritating
when i go to internet it appears and it hang my phone and internet connection will stop..please help me..
Eddy Mofo
3
Fix. Blow usb plug with compressed air then clean out with a small brush & a tiny bit of metho, cleaning alcohol, or something else that won't damage ur phone. Then blow it again. This worked for me. Also u can disable auto launch in car mode settings
aahma16
my s3 keeps switching on car mode by itself and then switching it off again a fraction of a second latter. On, off, on, off, on, off it's driving me nuts! I never selected the car mode in the first place (and don't know how to anyway!) it's making using the phone difficult at best and now i've had to switch the sound off on my device as it's constantly bleeping on and off! I need help please!
turn flight mode on and off it worked for me!
Ruben cc
Just wanted to thank you for the "clean with toothbrush" suggestion. I had the same annoying problem with my Galaxy Mega and cleaning the connector with an old toothbrush -and- using an air-pressure blower seemed to have fixed the problem.
CeCe Calvo
Seriously? Why should people type out the EXACT same issue they're having as all the others? I came here because I too am having these issues (that I will not type out word for word because everyone else has for me.) The main post says it all for you when we say we're having the EXACT SAME problem why do we need to type it all out?
But as I got on this post all I noticed was yours and that other dudes "solution" being so unnerving and OBVIOUS that I'm wondering how the heck you think you both are helping ANYONE? Come on. You don't think we've ALL restarted our damn phones? Why would we come here BEFORE taking the battery out? You can't POSSIBLY think you're helping anyone. Christ!
So yeah.... don't act like you can't solve a problem because its OUR fault. Seriously.
Umehuma
7
My S3 keeps switching on car mode by itself and then switching it off again a fraction of a second latter. on, off, on, off, on, off it's driving me nuts! I never selected the car mode in the first place (and don't know how to anyway!) It's making using the phone difficult at best and now I've had to switch the sound off on my device as it's constantly bleeping on and off! I need help please!
I too had the same problem. I switched off the Hands - free mode off and the car mode was gone. Try and see may be thats the problem.
AxlMyk
1,217
Just whom are you relating to? "Yours", and "That other dude" don't make any sense.
jello9
Hi David I just had the same thing happen to my phone and it started doing that car mode thing which is annoying. I finally got it to stop by downloading Antivirus security app in the play store. The app symbol has red, yellow, blue and green looking flags. After downloading it then click scan and once its done the car mode should go away.
Charlie Bartlett
on mine, it keeps turning on and off on and off turning my screen on and off etc. but when i restart it. it doesn't work i did a factory reset; still doesn't work. HELPPP
Mike Hernandez3
I was about ready to through my phone in the river, blowing out the charge port with a can of compressed air fixed it. The driving mode kept turning it self on and off for a couple of weeks...my phone works as it did before.
Apr 7, 2015
3
Hello, where did you download this app as I cannot find 'disable car home' app in google play. I tried searching 'disable car mode' and also nothing. I only found an app called 'Car Mode Off', I installed it and it hasn't solved the problem.
