Results 1 to 4 of 4
    mikeb6109's Avatar
    Posts
    Global Posts
    58 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help with custom rom
    I installed the AOKP ROM but my phone gets so dam hot when I play Gamez it worries me so I wanna switch to another one.how do I do it? Do I just install another like if I had regular ROM or do I need to go back to factory ROM then install new custom one?
    Plus not sure my recovery back up worked when I did install AOKP......am I in trouble?
    Also titanium backup shows installed but I can not find it.I did a back up after purchasing it,is that one good?
    Lots of questions sorry but appreciate all the help I can get.
  2. #2
    famouzstarz#AC's Avatar
    Posts
    Global Posts
    235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help with custom rom
    you sir shouldnt have rooted your phone! with root comes allot of unknown for newbs
    not sure what rom version your running or what modems you flashed / gapps
    download your new rom save to sd card
    boot into recovery make a backup
    factory data reset
    wipe cache
    wipe dalvik cache
    flash rom
    flash gapps
    reboot
    mikeb6109's Avatar
    Posts
    Global Posts
    58 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by famouzstarz#AC View Post
    factory data reset
    wipe cache
    wipe dalvik cache
    flash rom
    flash gapps
    reboot
    Thanks for the help. ROM I have installed is the newest AOKP jelly bean with gapps. Did everything step by step also the back up but it did not take long and not sure if it did properly. Anyway to find out?
    Again thanks for the help.
  4. #4
    Posts
    Global Posts
    235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you can try and restore the backup and see what happens but that AOKP i believe is a all in one rom / gapps .....give liquid smooth a try its stable its AOKP / CM 10.2 all rolled up together
