1. fauzia23's Avatar
    okay so my phone and battery were working perfectly (sort of) until i dropped the phone while it was on the charger. yup hit the ground charger port first. Now when i put my phone on the charger its loose as expected but it consantly does *charging, not charging, charging , not charging* off on off on SO FAST and now its pain to get it to charge by usb. so i tried an external battery charger (you remove the battery and put it in a dohickey.) EXCEPT the battery only chargers to 89% this way. external battery charger 1000mAh so maybe thats why but im not sure. I need to know if i should get my charger port fixed or buy a new battery or both!
    03-29-2013 08:31 PM
  2. meyerweb#CB's Avatar
    I'd bet on the micro USB connector, but there's probably no way to be certain. Do you know anyone else with a S3 you could swap batteries with for a few minutes to see what happens?
    If not, getting the port replaced / repaired won't be cheap, so you might want to by an inexpensive battery / charger from Amazon or ebay and see what happens before you have the phone repaired.
    03-29-2013 08:36 PM
  3. MoneySaver11's Avatar
    What you can do when your smartphone's charging port is broken?
    I I want to spend any money to fix it after I found out how expensive it was so I read this article, And have been using this product until I can upgrade to Verizon
    06-24-2013 12:10 AM
  1. Galaxy S3 charging issue
    By Axels15 in forum Samsung Galaxy S3
    Last Post: 09-18-2014, 01:01 PM
  2. Is your US Galaxy S3 made in China or Made in Korea?
    By Donta79 in forum Samsung Galaxy S3
    Last Post: 06-20-2014, 09:14 AM
  3. Galaxy S3 International-No 3G or 4G on T-Mobile
    By peppermintman in forum Samsung Galaxy S3
    Last Post: 04-09-2013, 10:17 PM
  4. Galaxy S3 unresponsive or huge delay when charging
    By prolvp in forum Android 4.0 Ice Cream Sandwich
    Last Post: 07-18-2012, 11:57 PM
  5. Is your VZW Galaxy S3 made in China or Made in Korea?
    By Donta79 in forum Verizon Galaxy S III
    Last Post: 07-06-2012, 09:48 PM
