Results 1 to 12 of 12
    chloe2013's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Not receiving texts but I can send them - HELP PLEASE!
    I just came back from abroad a couple of days ago and I can send text messages but not receive them from friends. I am with 3 network with my Samsung Galaxy S3 and have tried changing some settings and restarted and took out the SIM card for my phone, etc. I only then receive messages later once 3 helpline texted me then numerous texts came through after that one text. It happened again then again, my texts came through late. My texts take ages to come through, even hours. May someone tell me how to fix this problem so I can receive texts when they are actually sent by my friends?
  2. #2
    famouzstarz#AC's Avatar
    Posts
    Global Posts
    235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Not receiving texts but I can send them - HELP PLEASE!
    but your primary sim card into the phone, did you have to change any apn settings while abroad?
    chloe2013 likes this.
    chloe2013's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I took my sim card out then put it back in. I disconnected mobile data when I was abroad. I don't know what the settings should be, etc? Could you help please?
  4. #4
    Posts
    Global Posts
    235 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    im not sure what service provider your using so i cant really point you in any direction as far as apn settings,
    if on att:
    Go to the APN and reset to default with a CSC of BTU. AT&Ts APN is there.
  5. #5
    Gayle Campbell's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having similar problems and I'm with tesco mobile. Getting some texts but not all and have reset my phone and took out sim but still doesn't work.
  6. #6
    Gina Todd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same issue. I can send but not receive .....now here is what I can tell you after spending time on monitoring this issue. I can send out to everyone, I CAN RECEIVE FROM EVERYONE THAT IS NOT AT&T.
    NOW, IF THOSE MESSAGES ARE IN A GROUP TEXT... THEN I AM ABLE TO RECEIVE. ON ANOTHER ISSUE, I HAVE SENT A PICTURE TO ONE FRIEND (this friend is also with AT&T) AND THEN HE WAS ABLE TO RESPOND AND NOW WE ARE ABLE TO TEXT BACK AND FORTH.
    Please can you assist me with getting this fixed.
    Gina
  7. #7
    John Guillory's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I called AT&T and they helped me buy me starting off my phone they sent signals to my phone to make sure was on and it works fine after that.I hope that helped because I couldn't figure out any other way.
  8. #8
    Jay Couse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cannot receive TXT from one (very important) number where there is failed draft msg with a photo attached. I can see on the home screen that a new message has come from that phone number but when I try to open the messages from that particular account it displays the draft symbol (from the previous failed transmission). When I click on it I get an error message that messaging has failed. I tried to find options to clear cache or delete the app and re install. According to post factory resets may not fix this issue. I do not believe that deleting the contact would have any impact on this problem. New Rogers Wireless Samsung S3 (July 2013). Please assist
  9. #9
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Jay,
    If you delete that particular thread (long-press on the thread) can the sender resend the MMS?
    What does it show on the sender's phone - was the message sent successfully? Has this particular sender been able to send other MMS to you successfully?
    What Messaging app are you using?
    Sent from my SCH-I535 using Tapatalk 4 Beta
    Jay Couse likes this.
  10. #10
    Jay Couse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Problem solved. Long hold on the offending txt message (presents a new menu) cleared the buffers and the error condition is removed. Everything now working. Thanks a lot
  11. #11
    isurfer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Old thread but absolutely relevant to my problem:
    So, I can make and receive local and international calls.
    I can send local and international SMS messages.
    But I can only receive SMS from local numbers!
    My provider is Orange (Poland) and I am currently in Poland (so no roaming issues etc.).
    My device is Samsung Galaxy S3 mini, but I have tried with other device as well - problem remains.
    I have requested (and got) new SIM card - problem remains.
    Orange say everything is OK on their end, and I am stuck.
    Any ideas?
  12. #12
    John Poltoranos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi
    I have same issue did you able to resolved?
    Cheers
  1. Not Receiving Texts or Calls but can send out texts/calls
    By Shannon Winney in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 12-16-2012, 09:27 PM
  2. Can receive text but not send
    By cabbie0611 in forum Motorola Droid 2
    Last Post: 01-01-2012, 06:38 PM
  3. Sending but not receiving texts
    By nstigsell in forum Verizon HTC Thunderbolt
    Last Post: 05-08-2011, 09:16 PM
  4. SC 2.6 - Able to send but not receive text msg
    By rgm1266 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 02-28-2011, 09:20 AM
  5. Can't receive Gmail, but I can Send...
    By Hypnos in forum General Help and How To
    Last Post: 10-26-2009, 01:14 PM
