Results 1 to 4 of 4
    Jansen Bumanglag's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default need help with my samsung galaxy s3. it has a few problems. i hope these things will be resolved.
    My samsung galaxy is about half a year old or probably more. But recently it started acting up on me. 1.) The sd card wont read almost everyday and i have to restart my phone for it to work and i have to do this a few times not just once. And 2.) The music player installed in this phone is annoying. I put together a playlist and then suddenly it will all disappear. This happened all the time. I think this two problems are related to each other as i save my downloaded music in my sd card so i hope someone has suggestions in solving this, i would appreciate it so much. Thanks.
  2. #2
    hitsmanj's Avatar
    Posts
    Global Posts
    36 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: need help with my samsung galaxy s3. it has a few problems. i hope these things will be resolved
    what type/brand of sd card are you using? Several threads here dedicated to this issue and I recall one specifically noting a recall by Sandisk , though others using different brands also have reported problems. I believe most resorted to getting carrier to replace phone as Samsung was not acknowledging any problem. Search "sd card problem" in this forum for specifics. Good luck.
  3. #3
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's also possible to have a dying or bad SD card. They have a finite number of read/writes which means the life expectancy is limited. You could probably double your capacity now for the price you paid for the first SD card. No matter the cause I would get in the practice of backing up the contents of your SD to your PC on a regular basis. When bad things happen at least you'll have a recent backup.
  4. #4
    meyerweb's Avatar
    Posts
    Global Posts
    10,319 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The disappearing playlist has been reported by a couple of people, I think, so that may not be related to the SD card. There are quite a few aftermarket music players. MixZing is good, many people like doubleTwist, and PowerAmp is probably the most popular. I think they're all free, so give them a try.
    The first thing I'd suggest trying with the SD card is to dismount it (or turn the phone off), remove it from the phone, and reinsert it. Maybe do that a few times, to make sure it's making good contact. If that doesn't work, back up any information you don't want to lose and reformat it with the phone (not a computer). If that doesn't solve the problem, try a different card.
  1. Need help with my Samsung Galaxy s2 epic 4g touch
    By OscarReyes in forum General Help and How To
    Last Post: 04-06-2013, 03:27 PM
  2. Need help for my samsusng galaxy s3 battery issues
    By Steven_c901 in forum General Help and How To
    Last Post: 02-26-2013, 06:10 PM
  3. Replies: 7
    Last Post: 12-24-2012, 10:47 AM
  4. Need help with rooting Samsung Galaxy S3
    By Returns101 in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 12-10-2012, 02:03 PM
  5. Need help with my S3
    By briancook451 in forum Samsung Galaxy S3
    Last Post: 08-10-2012, 09:18 AM
