1. kulamachining's Avatar
    My galaxy s3 from at&t came stock as 4.1.1 i747. I flashed the CyanogenMod 10.1 4.2.2 rom, but I later discovered I wanted the stock 4.1.2 Jelly bean because of the features in the gallery, such as creating folders. Is there anyway I can flash the stock 4.1.2 Jelly bean ROM on my Samsung galaxy s3 i747 at&t? If so where can I find the downloads?
    04-14-2013 10:06 PM
  2. brkaras's Avatar
    Not available yet
    Sent from my SAMSUNG-SGH-I747 using Android Central Forums
    kulamachining likes this.
    04-14-2013 10:08 PM
  3. geekymcfly's Avatar
    Here's some google links. https://www.google.com/search?safe=o...loc=0&hl=en-US
    TMO GS3 * NEXUS 7
    04-14-2013 10:37 PM
  4. meyerweb#CB's Avatar
    OP, be aware that none of those links are for the stock JB 4.1.2 ROM. brkaras is correct that that doesn't exist yet. Those links are all for 3rd party ROMs, which may work great or may have annoying bugs. If you want to try them, make sure you make a nandroid backup of your current, working configuration first.
    geekymcfly likes this.
    04-15-2013 08:28 AM
  5. kulamachining's Avatar
    How do I know when it will be available?
    04-15-2013 05:27 PM
  6. geekymcfly's Avatar
    Has far as the official stock 4.1.2 you'll be notified by ota. You'll also be notified by someone either on this forum/some blog/or some app like drippler. Now about a rom you can use that link i posted and search around for a stable stock rom which you can flash right now
    TMO GS3 * NEXUS 7
    04-15-2013 06:21 PM
  7. meyerweb#CB's Avatar
    You don't. No one, except maybe people in Samsung and the carriers know.
    Sent from my Sprint Galaxy S3. Please forgive any typos or auto-correct errors.
    04-15-2013 06:28 PM
  8. kulamachining's Avatar
    Is there anyway to get the Samsung features back on it such as S voice, S memo etc.?
    04-24-2013 04:48 PM
  9. meyerweb#CB's Avatar
    There's no way to add them to CM.
    You can flash the original AT&T ROM, or look for a modified Touchwiz based ROM. Just make sure any ROM you flash is designed specifically for the AT&T S3. All S3 ROMs are not alike.
    04-24-2013 05:22 PM
  10. kulamachining's Avatar
    Does the stock ROM come with the Samsung features or do I have to download them separately
    04-24-2013 08:49 PM
  11. minnick's Avatar
    http://forum.xda-developers.com/show....php?t=1968625
    I believe those are the latest stock firmware files, don't know what OS versions they are. I'm on cm 10.1.
    Use the search function on here and XDA site and you should find answers.. Btw, Kula, Hawaii?
    04-24-2013 09:07 PM
  12. meyerweb#CB's Avatar
    The stock ROM should included everything. BTW, note that there is an AT&T specific subforum here, and under that a Rooting subforum specific to the AT&T Galaxy S3. That's probably a better place to look for answers to questions about ROMs for your phone.
    04-25-2013 09:30 AM
  13. kulamachining's Avatar
    Thanks, its polish
    04-29-2013 07:11 PM
  14. kulamachining's Avatar
    I don't see the subform. Could you include the link please?
    04-29-2013 07:13 PM
  15. marshjuliechristmas's Avatar
    You seem to be very knowledgeable about this stuff, I NEED HELP!!!! Ive been jailbreaking and rooting phones for about 8 years or so and I made the dumbest error in the world.... Long story short, I tried to root my galaxy s3 and used wrong root... Im stuck in "firmware upgrade went wrong!!!!" (that's not exactly what iwww.sammobile.com/firmwares/1.?model=sch-I535t says but I think you understand), anyway, I can ALSO get to my downloading screen, but the long and short of it is I need the stock firmware to load through odin. My phone is a Galaxy s3 model # sch-s960L and its through straight talk / tracfone. since its through those carriers you know I spent 430 bucks on the thing and had it 3 HOURS before I BECAME THE DUMBEST PERSON ON EARTH!!!! I am afraid the stock firmware does not exist... I am willing to donate to ANYONE who can get my phone back to how it was before or even tell me how or where to look.... even tell me where to take the phone. If you can help, (I have never posted or asked for help so I don't know protocol) just email me at [email address removed]. I appreciate you even reading something that took pure ignorance to accomplish!!!
    06-02-2013 09:58 AM
  16. meyerweb#CB's Avatar
    http://forums.androidcentral.com/t-galaxy-s-iii/
    06-02-2013 02:28 PM
  17. jerry00020001's Avatar
    The same thing happened to me! I have a galaxy s3 that i got from StraightTalk with the model number SCH-S960L. I tried to root, but now it only turns on for 2 seconds then stops working altogether. I have to take the battery out to "reset" it. I can still go into download mode and recovery mode, but nothing works.
    06-25-2013 03:24 PM
  18. meyerweb#CB's Avatar
    What procedure did you follow to root, and what ROM did you try to flash?
    06-25-2013 09:48 PM
  19. jerry00020001's Avatar
    Well first I downloaded Odinv3.07. Then I got this file "CF-Auto-Root-t0ltevzw-t0ltevzw-schi605.tar.md5" from the autoroot.chainfire.eu website. I tried to flash the phone, and it said it worked. But when it tried to reset, it couldn't. It would turn on for about 2 seconds then turn off. If I try to turn it on, it would only turn on for 2 seconds then shut off. I can still get it into download mode, but I can't find a firmware for the model # SCH-S960L
    06-26-2013 04:27 PM
  20. Ruger0045's Avatar
    did anybody figure out how to root the sch-s960l?
    07-14-2013 10:25 PM
  21. w0ng's Avatar
    isn't that for note 2 verizon?
    Sent from my SCH-I605 using Tapatalk 4 Beta
    07-14-2013 10:33 PM
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 06-02-2013, 03:17 PM
  2. HELP! Need Jellybean 4.1.1 firmware package for Galaxy Nexus!
    By slk723 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-16-2012, 08:10 AM
  3. Firmware issue help needed
    By Kilted_One in forum Samsung Galaxy S II
    Last Post: 08-30-2011, 03:53 AM
  4. Help Needed Please
    By laraiza in forum HTC Hero
    Last Post: 12-17-2009, 04:09 PM
  5. help need calendar & address book
    By gadget in forum Android Apps
    Last Post: 11-22-2009, 08:46 PM
