The Samsung Galaxy S3 is a great device, however just as with any other handset the battery life can be an issue. So with this in mind you may wish to follow these tips and tricks to help you get the most of your battery life.
Stop push email and you can save your battery life. Instead of having your mail pushed you can check for it at a set period of time. The longer you leave the interval gaps, the more battery life you will save.
Try to keep your Samsung Galaxy S3 on charge whenever possible and never let the device run down to the point where it turns off. By doing this it will affect your battery health over the longterm.
Your live wallpaper might look great but it does drain your battery. So turn this off and have static wallpaper instead. You might want to have a dark one, which is also better for battery life when it comes to AMOLED screens such as the one on the Samsung Galaxy S3.
Turn down your brightness to as low as you cans stand or choose the auto brightness setting to save even more battery life.
Turn off 3G, GPS, location services, Bluetooth and mobile hotspot to save battery, when you don?t use these.
You should also un-install apps that you don?t use and this will make sure that they do not run in the background. Keep any apps that you do want to use up to date on your Samsung Galaxy S3.
Source: Sidhtech
Source: Sidhtech
