1. awengca's Avatar
    Android system draining battery.. the top user is iot hidden menu taking more power than the screen. Is there a quick fix for this? My battery has been running down to 30 percent and its not even 1 pm. This just started happening today
    05-30-2013 02:52 PM
  2. friedtators's Avatar
    what new app did you install? go to mange applications and look in the running column. tap the item and it should show you whats using it. hit stop and uninstall the app until they fix it
    Roll_Cam_Tide likes this.
    05-30-2013 03:51 PM
  3. Simone C's Avatar
    I'm having the same exact issue & if you look "iot hidden menu" up it shows up as a key-code for service industry people to check all of the main features of the phone, but it's not supposed to be enabled all of the time& you have to dial the code to get into it every time still.
    It's not an app-related issue it's got to be a system error because I'd never dialed the code until I saw it taking up all my cpu/mem &looked it up, what I didn't find was anything about how to disable it/make it inactive again...
    08-15-2013 10:12 AM
  4. meyerweb#CB's Avatar
    If you reboot the phone, does the problem continue?
    08-15-2013 06:18 PM
  5. Mike Drudy's Avatar
    Rebooting lowers all memory and battery hog issues temporarily.
    This one returns and grows over time.
    I have the same problem, but it's affecting memory usage also.
    Three processes have the exact same memory usage ALL the time.
    I find that odd.
    CSC
    IOTHiddenMenu
    Bluetooth Test
    08-17-2013 07:57 AM
  6. GSDer's Avatar
    Mike,
    Assuming that you're using Settings -> Application manager -> Running to get this information on running processes, I don't see any of the 3 apps that you listed shown in my list.
    - if you're using a different app let me know and I'll give it a try
    - do you normally have Bluetooth enabled?
    Too bad there's not a way to export that list so we could see what's common and eliminate those from consideration.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-17-2013 12:43 PM
  1. Battery Drains when the power is off..
    By cy8ercop in forum Motorola Droid
    Last Post: 08-21-2010, 09:22 AM
  2. Battery drain
    By Snipperdo17 in forum Motorola Droid
    Last Post: 02-02-2010, 04:43 PM
  3. 2.0.1 battery drain?
    By droidweasel in forum Motorola Droid
    Last Post: 01-19-2010, 07:45 PM
  4. battery drain when device is off?
    By sicario666 in forum Motorola Droid
    Last Post: 01-04-2010, 11:40 PM
  5. My battery drained overnight
    By pbrennan42 in forum General Help and How To
    Last Post: 01-02-2010, 02:30 PM
