hey guys
there is lot of forums around but l did not find anything what did the job.
my problem is only fully charging if the phone is off.just to mention my phone is galaxy note 7000 but you find most galaxies forums the same problem.
l tried so far :
new battery, nothing
new chargers bought, nothing
cleaned all kind of parts inside the phone,nothing
moved the central pod in usb port once up ,nothing, then later moved it down, nothing
tried lg charger and other samsung charger , nothing
i bought and installed new usb port on phone and i found little progress here:
if i connect to laptop it is being recognised but still not charging, while with the old usb port connected to the laptop it wasnt recognised at all.
so new usb port in and still not charging,
then i did the above mentioned cache wipe, and at this point am not sure if did it right or not. because it was done in something like 3sec or less.
then reboot the system, the phone is on, and not charging again
some guys saying charge it to full100% but i only can charge it now with phone being s/off
so waiting now to be charged fully. if it works, i let you know in couple of hours.
( I doubt it anyway ):-\
the last option is an old good hammer.
update:
still the same, no difference.
I think over again and maybe the usb port i got is not genuine, i ordered another one today, clearly stated as oem (original equipment manufacturer) with GH59-11676A code it costed me 3times more as one before around 23pounds in uk. i do update later. see what happens.
