Difference between original S3 or S3 mini and fake / clone
mcz1990
3
The hardest to tell among all the fakes is the 98% clone especially if you base it on the appearance. Every spec is copied down to the menu and to the icons. But one give away to ALL the fakes even the 98% clone is in the menu. There is no way a fake/clone samsung could have access to the samsung app store so check it carefully. In the original samsung s3 or s3 mini the app store is supposed to say "Samsung Apps" while in all the fake ones it only says "Apps".
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
The best way to avoid the problem is only buy from a reputable carrier/OEM store or authorized reseller. When it comes to thinking your going to get your hands on the next latest and greatest off some internet store or overseas thru some advertisement is a huge gamble I'm not willing to take.
kirk781
