Samsung Galaxy S3 fast battery drain and super hot
emilyggolladay1
Over the past few days I noticed I would charge my phone all night long and would wake up and it be fully charged. But I would unplug it for about 2 hours and it would be all the way at 25% or even lower? It has never done this before and I have not done anything different with it. Also it will get extremely hot at night and random times when I am not even using it. I have turned it off and on multiple times. Also I have let it die completely and let it charge back. Last time it started acting like this just a little bit there was an update the next day. Does anyone know what is going on? My carrier is Sprint.
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
Have you rebooted it? If not, before you do, look at the battery stats page in settings and see what's using battery. If you want help, do a screen capture of the battery page, then tap the graph and do a capture of that screen, too. Post them both here. Then power down, pull the battery, wait a few minutes, and reinstall the battery and power back up. See if that solves the problem.
This thread may be helpful: http://forums.androidcentral.com/sa...android-system-eating-your-battery-check.html
calvinxander08
