well i am confused, with this issue. well i wanted to put music on my phone and move pics around to put on the desktop, well it kept on freezing up on me with the phone plugged in. so i removed the sd card from the phone stuck it in the pc and it loaded the music (400 songs) in a couple of seconds, compared to 2 min and nothing (phone connected to pc) so i was able to put all the songs i wanted (198 songs added). its time consuming this way but it works umounting the sd card, removing otter box defender, putting files on, putting the sd card back in, then putting the case back on. compared to the way it worked before, get cable plug in phone transfer files.
i havent had this issue, since i had the phone even when it was rooted and running custom rom's. sorry if my post is hard to follow so here is the short version.
problem the sort version
phone connected to pc is slow when trying to load files causing the pc to crash
memory card connected to pc is fast when loading and writing files
the laptop in general is fast and doesnt have any issues loading the 4gb of songs i have on the memory card. and the phone cable is top notch, monster audio cable (the only cable that i buy unless they dont have it)
any ways i hope yall can help me figure this out this one has me scratching my head (i have re-instilled the drivers and it still does it
